Please help. About headlights.
Old Jun 23, 2025 | 09:41 AM
kazishi's Avatar
kazishi
Default Please help. About headlights.
Today, the headlight on the passenger side has stopped opening at all.
I think it might be a gear failure.
I am trying to fix it, but the headlight will not open even if I do it manually.
Is there any way to fix it?
Sorry if my English is wrong.
Old Jun 23, 2025 | 09:56 AM
Joe Scafide's Avatar
Joe Scafide
Try turning the knop on motor
Old Jun 23, 2025 | 10:47 AM
Ltngdrvr's Avatar
Ltngdrvr
Yes, turn the **** on the motor while pulling up on the headlight door.
Old Jun 23, 2025 | 11:38 AM
Vader_C5's Avatar
Vader_C5
2023 C5 of the Year Winner - Unmodified
St. Jude Donor '25
As others suggested, you can manually operate the lights. But yes, new gears are likely in order, should your motor be functioning.
Old Jun 23, 2025 | 11:58 AM
kazishi's Avatar
kazishi
It does not come up in a spinning state when I turn the **** while pulling it up.
Do I need to pull harder?
Old Jun 23, 2025 | 12:02 PM
kazishi's Avatar
kazishi
When I turn the ****, it doesn't come up as if it is idling.WhIcptrntheknob,eem to be dland llnome
Old Jun 23, 2025 | 12:03 PM
kazishi's Avatar
kazishi
No response when manually turned...
Old Jun 23, 2025 | 03:29 PM
Milan's Avatar
Milan
Are you turning it clockwise? You have to keep turning it sometimes it can take quite a few turns
Old Jun 24, 2025 | 02:52 AM
kazishi's Avatar
kazishi
I didn't know which way to turn it, so I turned it left or right.
Old Jun 24, 2025 | 07:19 AM
Moved to C5 Tech for more assistance.
Old Jun 24, 2025 | 06:40 PM
kazishi's Avatar
kazishi
I understand.
Old Jun 28, 2025 | 08:45 AM
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
Turn the **** while manually lifting the headlight with your other hand. This will help the gears to engage.
To Please help. About headlights.
