6 speed manual
I don't know that I believe either claim but it's easy enough to find non-synthetic just in case there is something to the complaints.
This may be what you were looking at as far as fluid recommendations, https://www.txdrivetrain.com/fluid-t...56-tr6060-faq/
I only bothered looking at information for one Amsoil product and it's synthetic and Dex III compatible.
https://www.amsoilcontent.com/ams/li...tins/g3110.pdf
"Use AMSOIL Signature Series Multi-Vehicle Synthetic ATF in
transmissions, hydraulics, power steering systems and other
APPLICATIONS THAT REQUIRE ANY OF THE FOLLOWING SPECIlCATIONS
Allison C-4, TES-389; BMW 7045E, 8072B, LA 2634, LT 71141; Chrysler ATF+4*, MOPAR*
ASRC, 68089195AA, 68049954AA; Ford MERCON*, MERCON* V, ESP-M2C166-H, FNR5,
M2C924-A, XL-12; GM DEXRON* II, DEXRON* III, AutoTrak II; Honda/Acura ATF-Z..."
Transmission Fluid - Manual
https://www.corvetteforum.com/forums...id-manual.html
I just purchased Mobile ATF D/M from Rock Auto for a good price.
Penzoil (and Mobil 1) sell "Automatic Transmission Fluid" that'll work. Just read the label, look for Dex III compatible and non-synthetic
Even though I don't believe it it recommended for the application I am tempted to try Pennzoil Syncromesh.
I've used it in other T56s with amazing results. I've also used it in ZF6s, Tremec 3650s and T5s.
More reading.
