Keep an eye out for the Truck Adapter Kit going on sale. The extra height is worth the couple of minutes of extra effort!
I have thought about the truck adapters. Seems like I would have to raise the vehicle up first on the pucks then Lower onto my ramps to get the adapters positioned. Not a big deal to do this but wondering if that is how you the adaptors in place? Tks
I've been fine on the stock chucks with a lowered car for ripping out and swapping in the entire drivetrain. As a normally solo show I had an easier time without it being jacked higher because otherwise I'd have had a lot harder time getting the big parts back into place.
Did those work for you? I have 7000 TL and wanted to know if anyone has used the drop in trays on the TL versions
Yes, I have a set for my 7000TL. Works great with the C5 lift points. Before these came out I was just using four plates of 1/2" steel across the QJ frames, but that worked fine also.
