Help
Old Sep 30, 2025 | 03:57 PM
Co123456!'s Avatar
Co123456!
1st Gear
Default Help
I know that I messed up but now I need to fix my issue so please no bad comments . I accidentally lock my keys in my running 04 corvette by the time I got someone out it had been 21/2-3 hours and now it’s on reserve fuel my brother thought he would help me out and put gas it in for me however it was the wrong kind but only like a gallon I then drove it about 2 miles and then I put the the right gas in however by now the check engine light was in and it had misfire a few times I got it home and have not started it up since. I do take care of the engine ect so it was in good shape but what kind of damage have I done and what to do
Old Sep 30, 2025 | 04:14 PM
Doke's Avatar
Doke
Not sure about this but depending on how long it ran it might fine since the new gas is in. I believe you said 04. So it has two balanced tanks. But let someone else chime in that has mechanical knowledge.
Old Sep 30, 2025 | 04:25 PM
Ltngdrvr's Avatar
Ltngdrvr
The wrong kind of gas???
What does that mean???
If you mean it was just lower octane, then it won't make any difference at all and that would not be the reason for the CEL to come on.
You need to check the codes and tell us what they are.
Old Sep 30, 2025 | 05:02 PM
Sydwayz's Avatar
Sydwayz
St. Jude Donor '18
Unless he put diesel in it, the gasoline OCTANE doesn't matter.
So, 1 of 4 things has happened.
1) whatever gas he put in was old/stale
2) he may have put 2-stoke premix gas in, perhaps made for weedeater/whatever
3) he put diesel in it
4) the tank ran down so low, that all of the junk that floats around in a tank has now been sucked up into the fuel pump and fuel filter
So, find out what EXACTLY what he put in there, first.
If it is diesel, real bad. You need to NOT run it again, and have the tanks evacuated, lines purged ,change the fuel filter, and fill with 93. Hopefully the injectors and/or pump(s) are not damaged
If it's the latter, start with filling it up, change the fuel filter, and see where it goes from there. If you dissect a fuel pump, you will find it has a small sock on it. That could very likely be cached with crap, and the whole pump(s) assembly(s) should be replaced as well as fuel filter.
Old Sep 30, 2025 | 06:19 PM
Dads2kconvertible's Avatar
Dads2kconvertible
This is a silly old wives tale. It's typical for a vehicle that has run out of gas to run fine with no additional issues when fuel is added.
As a general rule fuel tanks don't have huge wads of junk floating around.
Old Sep 30, 2025 | 06:35 PM
Sydwayz's Avatar
Sydwayz
St. Jude Donor '18
Well, I have personally killed fuel pumps identical to what is in a C5 in my Mustang racecar due to gummed up socks within the housing whereas when debris does make it's way in there, it really doesn't come out...
...so there is that.
No photo description available.
Old Sep 30, 2025 | 06:43 PM
Ltngdrvr's Avatar
Ltngdrvr
Yeah, but that's a Ford...
Old Sep 30, 2025 | 07:48 PM
killain's Avatar
killain
Oldtimer
I'm not trying to be cute, but how did your brother get fuel in it since the only way to open the gas door is either in the car or by the emergency cable in the trunk ? Hope everything worked out for you !
Old Oct 1, 2025 | 08:21 AM
glbeauchamp's Avatar
glbeauchamp
Beat me to it!😁
Old Oct 1, 2025 | 09:15 AM
pjdbm's Avatar
pjdbm
IDK, It's too late to be April fools..........
Old Oct 3, 2025 | 07:03 PM
Good luck - hope this is something that can be fixed easily and inexpensively.
Old Oct 4, 2025 | 07:00 PM
3sACROWD's Avatar
3sACROWD
Pull your codes and see what they relate to. Clear the codes and see if they come back. If you opened the tank while it was low, you may have just set the code for a non-seated gas cap.
Old Oct 4, 2025 | 07:12 PM
Dodosmike's Avatar
Dodosmike
Im zero help, but damn, that was hard to read.
punctuation man, punctuation.
Old Oct 5, 2025 | 12:18 AM
RC81's Avatar
RC81
Dude hasn't even been back to comment in many days.....hmm.
Old Oct 5, 2025 | 10:17 PM
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
I smell a troll......
Old Oct 6, 2025 | 05:04 PM
Dodosmike's Avatar
Dodosmike
Oh 100%. first post, ***'mon man.
Old Oct 6, 2025 | 05:32 PM
hyperv6's Avatar
hyperv6
21 hours was a good clue for a troll. Wrong Gas? Never reset or read the codes.
He went fishing here.
To Help
