Reverse Light Bulbs
Old Oct 13, 2025 | 03:12 PM
Ltngdrvr's Avatar
Ltngdrvr
Default Reverse Light Bulbs
Anyone seen these custom cream colored reverse light bulbs before?
They don't light up worth a darn!
Gonna get some LED bulbs to try.
Old Oct 13, 2025 | 05:07 PM
killain's Avatar
killain
Oldtimer
I replaced my stock bulbs with the LED from Vette-lights, and they are perfect. Lights up my driveway almost all the way out, but certainly better that OEM by 1000%
Old Oct 13, 2025 | 05:25 PM
Ltngdrvr's Avatar
Ltngdrvr
I just ordered some cheap ones from amazon.
Old Oct 13, 2025 | 05:31 PM
Ed Ramberger's Avatar
Ed Ramberger
Order the Adjure Diamond Cut reverse light housing if you want your reverse and approach lights to be like daylight. It's about $90 if you look around.
Old Oct 13, 2025 | 06:44 PM
Ltngdrvr's Avatar
Ltngdrvr
Nah, not worth that to me.
I almost just went to walmart and bought standard bulbs.
And, I may still if I don't like the results of the cheap LED's.
Old Oct 14, 2025 | 08:37 AM
glbeauchamp's Avatar
glbeauchamp
Leds, cheap or not, are far superior to the stock bulbs. And unlike tail or brake bulbs, no need for resistors!
Old Oct 14, 2025 | 09:53 AM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
Vette Lights LED back up lights with Diamond Cut reflector. You might blind a few people, but you certainly will see anything behind you.
Old Oct 14, 2025 | 05:40 PM
Ltngdrvr's Avatar
Ltngdrvr
Amazon dropped off my bulbs a little while ago.
Got them in and working, YAY!!!
Couple of pics, hard to tell much in the daylight, will get another after dark.
I think they will be fine, definitely better than burnt out bulbs, especially for $8 for 4 bulbs!
Old Oct 14, 2025 | 07:31 PM
Ed Ramberger
I think this was like midnight with high output reverse LEDs and the Adjure assembly. The lights carry really far. As approach lights no one could be hiding lol.
Old Oct 14, 2025 | 09:16 PM
Ltngdrvr's Avatar
Ltngdrvr
Well, I think these are just right for me, plenty bright without being so bright they want to melt the lenses.
And, the price is even lower today than it was yesterday, $7.57 instead of $7.98, so now they are less than $2 each!
Amazon Amazon
Old Oct 14, 2025 | 11:41 PM
Ltngdrvr's Avatar
Ltngdrvr
So, maybe someone can shed some light on this question...pun intended!
The bulbs spec'd for the reverse lights are a dual filament bulb, 2057, with a high and low side, like for a tailight/stoplight bulb, but the reverse light socket only uses one side of the bulb, only has one contact at the bottom of the light socket, why would they do that?
Basically wasting half the available lighting of the bulb.
Old Oct 15, 2025 | 01:34 PM
Ed Ramberger
When I worked with OEM manufacturing, anything to commonize parts was a goal. Then you stock less assembly line and service parts, and get a better discount on the volume purchase.
Old Oct 15, 2025 | 02:02 PM
Ltngdrvr's Avatar
Ltngdrvr
That would track, except that the taillight bulbs are plug-in and the reverse light bulbs are twist in!
Old Oct 15, 2025 | 04:49 PM
Ed Ramberger
Who knows. GM used to make a ton of different cars. Maybe they got a deal.
Old Oct 15, 2025 | 07:43 PM
CFight's Avatar
CFight
Projectors retrofit.
Old Oct 16, 2025 | 12:50 PM
That has the potential of being like looking into the sun.
Old Oct 16, 2025 | 06:21 PM
DanielW's Avatar
DanielW
St. Jude Donor '04-'05-'06-'07-'08
Could also be used to manually turn on if someone is tailgating you with high beams on. 😃
To Reverse Light Bulbs
Old Oct 17, 2025 | 08:12 AM
glbeauchamp
Or you could back up at 60 mph and not outrun your lights
Old Oct 17, 2025 | 09:46 AM
Six7390gt's Avatar
Six7390gt
2021 C5 of the Year Finalist - Unmodified
St. Jude Donor '25
https://www.amazon.com/dp/B0DSL796JJ...sin_title&th=1
I installed these bulbs yesterday. they are much brighter than stock. However, after they have been on, and I take the car out of reverse they are still dimly lit. Did you have this issue?
I read I could solve this by installing an inline resistor, but I don't want to cut into the factory wiring for that. Is there another solution? Or are there LED bulbs that don't stay lit when they should be off?
Old Oct 18, 2025 | 12:29 AM
Ltngdrvr's Avatar
Ltngdrvr
Really? Hmm...
I have not noticed anything like that, but I have yet to try it in the dark since installing the bulbs.
Hope it doesn't do that with the key off, drain the battery and give a no-start!
