Changing the differential oil ?
Old Oct 24, 2025 | 12:39 PM
killain's Avatar
killain
Oldtimer
Default Changing the differential oil ?
I was looking for the Limited slip oil, but there's a lot and I don't see the fluid type od GM Part # Can someone help me ?
How long does Gear oil last, My car is 22 years old, and it only has 11K miles. I don't think I ever asked this question ?
Old Oct 24, 2025 | 12:52 PM
Ltngdrvr's Avatar
Ltngdrvr
GM part number has changed, twice I believe, but you don't need it.
75w90 NAPA or valvoline LS lube is all you need, has the friction modifier mixed in already, takes just under two quarts.
My diff fluid change video...
Old Oct 24, 2025 | 02:05 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
A lot of good oils already have the limited slip additive in it.
I like to use AMSOIL in my car and no additional additive is needed.
https://www.amsoil.com/p/amsoil-seve...-EA?zo=1934716
Full size image for SEVERE GEAR® 75W-90
Old Oct 24, 2025 | 02:15 PM
killain's Avatar
killain
Oldtimer
OK great, there are some GM Limited slip fluids on the market and with each a different number. Thank's. I wonder why there are so many GM Limited slip-oils with different part numbers ?
Old Oct 24, 2025 | 02:58 PM
Ltngdrvr's Avatar
Ltngdrvr
Anytime they change any spec or formulation or supplier, they assign a new part number.
There really is no good reason to use the more expensive GM lube, the Valvoline is perfectly acceptable and best price,
Old Oct 24, 2025 | 03:29 PM
Kubs's Avatar
Kubs
It doesnt have to be GM....
Old Oct 25, 2025 | 01:46 PM
RogerZ06's Avatar
RogerZ06
I changed mine with royal purple couple days ago. Its actually a very easy job.
Old Oct 25, 2025 | 03:23 PM
Ltngdrvr's Avatar
Ltngdrvr
Yeah, some Corvette engineer had his head screwed on straight when they designed the fill and drain plug access.
If all the engineers that worked on the C5 had only been as thoughtful...
To Changing the differential oil ?
