Interior Sound Deadening
Just got a little done so far, then had to take a break to run to the UPS store to return the roller tools amazon sent me, because they sent the wrong ones.
And, even though there isn't much back there yet, and the carpet is out, I believe I can tell a difference in exhaust noise coming through.
Maybe it is because the part I covered so far is at the very back where the exhaust outlets are closest.
Goes on fairly easy, but since amazon sent me the wrong roller tool set, will be end of week before I can get all the materiel rolled out for the best bond.
Looking forward to getting it all done and the carpet back in, that along with the new quieter exhaust, should make for a much nicer ride.
My appointment to get the exhaust done is in the a.m., maybe get back on it tomorrow afternoon.
The new exhaust is so much quieter than the Borla Stinger, that it already seems like a totally different car, it's so quiet inside now.
Looking forward to it getting even more quiet once all the sound deadening material is down and all the carpet is back in place.
I haven't put the carpet back in yet, still have to lay the wiring for the exhaust valves, but I did put the covers back on the storage compartments, which I also lined with sound deadener, and I tossed the carpeted cargo mat in, and took a drive to walmart, and the interior is so QUIET now, it is just amazing!
It's going to be even better with the carpet back in, going to be great!
The new head unit won't be competing with the exhaust to be heard!
I made a thread a while back about "Quality of life mods" and this is definitely one that adds as much "quality of life" to the drive as the C7 seats!
what is the name of this product please ?
Super sticky, peel backing and stick it down.
Mine came from amazon, best price I found,
https://www.corvetteforum.com/forums...g-article.html
Just doing the cargo area was a big enough drain on me, and I didn't go as far back there as you did!
And, my understanding, after some additional research, is that you really don't have to cover every square inch, just major areas to reduce vibration and resonance.
Mine came from amazon, best price I found, https://www.amazon.com/dp/B0F1MV7GRF...fed_asin_title
Now, my two corner storage compartments look like patchwork as I used all the cutoff pieces to do them.
I may put a couple of sheets on the bulkhead behind the seats, but only if I can get to it without taking anything else loose besides the carpet.
..... I took all the plastic panels off and fixed some to the back sides. Not to cover them. And done carefully so the pieces fit back in place. But to dampen vibration. Tap the cheap plastic afterwarsa and it sounds much heavier and less cheap rattle cage.
