1999 frc............
Nov 24, 2025 | 10:51 AM
Need one tire air sensor Best place to get one?..............
Nov 24, 2025 | 11:36 AM
"Best" is subjective. Since you've provided no criteria for determining what constitutes best for your situation I say your local auto parts store.
Nov 24, 2025 | 11:49 AM
Well to answer your question.
If you know what you want Amazon.
If you need help then go to a web company like I did like Summit Racing or local parts store. They may have to order locally but they should be able to match what you need. Just make sure to have the year make and model and Vin.
I bought Schrader.
Nov 24, 2025 | 11:53 AM
Go to Rock Auto and buy the Schrader 29178, which is the correctly programmed Schrader replacement for 1997-2000 Corvettes. Replace all four while you are doing this. These will absolutely work. I also have a 1999 FRC, tell me more about yours.
Nov 24, 2025 | 12:10 PM
Rock Auto is a good source for reasonably priced parts.
Nov 24, 2025 | 05:35 PM
I bought mine at Discount Tire.
Nov 25, 2025 | 12:39 PM
Nov 25, 2025 | 12:46 PM
Quote:
Originally Posted by
clutch1
Dick
well, that escalated quickly.
Nov 25, 2025 | 12:51 PM
25981210
GM has plenty.
$250-ish
Nov 25, 2025 | 01:20 PM
DREEZZEE
25981210
GM has plenty.
$250-ish
The Schraders on RockAuto are guaranteed to work and the OEMs were Schrader as well. Less than $100 for a set of 4.
Nov 25, 2025 | 01:58 PM
replace all 4, another one will go out soon I bet. You don't have to take the tire off the rim, but you do need to take the tire off the car and break the bead.
Nov 26, 2025 | 07:48 AM
I have four Schrader #28006 TMPS in my '99 FRC that I sourced from RockAuto back in 2023 and they work great,
Nov 26, 2025 | 11:21 AM
