Is it wobbling?
Old Dec 5, 2025 | 10:29 PM
ZackPopulus's Avatar
ZackPopulus
5th Gear
Default Is it wobbling?
My buddy and I are going to look at this 04 Z. The seller called us this morning saying he heard a squeaking noise on cold start from the engine. He sent the following video to show us the harmonic balancer. The vid isn’t awesome, but what do y’all think? Is it wobbling?
Old Dec 5, 2025 | 10:44 PM
Ltngdrvr's Avatar
Ltngdrvr
You should upload the video to youtube then link it here, otherwise it has to be downloaded to be able to see it, and I don't download files like that.
Old Dec 6, 2025 | 12:44 AM
BLOCKA3's Avatar
BLOCKA3
I'm the buddy, heres the YouTube link
https://youtube.com/shorts/ooMc6pH5iV8?si=nsdx9Hc6VGoDf65P
Old Dec 6, 2025 | 05:52 AM
alex04vette's Avatar
alex04vette
2024 C5 of the Year Finalist - Unmodified
Looks healthy to me. I would be more concerned with the squeal
Old Dec 6, 2025 | 05:54 AM
BLOCKA3's Avatar
BLOCKA3
The owner did report a squeal
/squeak that started very recently and went away with heat. Assuming its belt/ accessory related
Old Dec 6, 2025 | 09:41 AM
WFD714's Avatar
WFD714
Cruising
Looks good to me also.
Old Dec 6, 2025 | 11:23 AM
Ltngdrvr's Avatar
Ltngdrvr
I don't see any appreciable wobble, but even if it were, that is not a reason to pass on the car, just something to plan on changing out.
Squeak/squeal on cold start is likely an idler pulley, and could go for a very long time without being a big issue.
Old Dec 6, 2025 | 01:59 PM
hyperv6's Avatar
hyperv6
The damper is good. Check the tensioner and belt. The tensioner may be weak and or the belt may be glazed a bit. Easy and cheap to change both.
Old Dec 7, 2025 | 10:16 PM
Old Dec 8, 2025 | 12:38 PM
ZackPopulus
5th Gear
Thank you for the input! We fly out to inspect it on Sunday so we will update if we end up buying it.
To Is it wobbling?
