Cray Eagle wheels c5
Old Dec 7, 2025 | 11:30 PM
c5Vettev8's Avatar
c5Vettev8
5th Gear
Default Cray Eagle wheels c5
has anybody fitted Cray EAGLE 19x9 ET50 5x120.65 front and rear Cray EAGLE 20x10.5 ET69 5x120.65 to a c5 and know if there fit
Old Dec 8, 2025 | 12:08 AM
Ltngdrvr's Avatar
Ltngdrvr
Those rear wheels are C6/C7 offset, so to run them on a C5 you would want to use spacers.
You could bolt them on without spacers, but the rear wheels would be sucked in.
Old Dec 8, 2025 | 02:55 AM
USAZR1's Avatar
USAZR1
Those 19x9 fronts will fit fine on a C5, or a base C6/C7 front w/o spacers. Those 20x10.5's will also fit your C5. Though the backspacing isn't optimum, they will work, but a 6mm hubcentric spacer will give a better fitment.
Old Dec 8, 2025 | 05:28 PM
c5Vettev8's Avatar
c5Vettev8
5th Gear
i have michelin tires on the car now with 255/35/zr19 FRONT and 285/30/zr20 REAR will these be ok to use on this wheel setup ? thanks
Old Dec 8, 2025 | 06:05 PM
Ltngdrvr's Avatar
Ltngdrvr
Yes, they will fit those wheel just fine.
Old Dec 9, 2025 | 03:45 PM
USAZR1's Avatar
USAZR1
And a 295/30/20 or 305/30/20 will fit nicely on those 10.5" width rears, if you so choose.
To Cray Eagle wheels c5
