radio
Old Feb 10, 2026 | 06:55 PM
namvet6869's Avatar
namvet6869
Default radio
Can you get to the back of the radio through the glove box area??????????
Old Feb 10, 2026 | 07:06 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
No afraid not. You have to go through the process of removing the trim bezel to access. Do a search on the removal process. You’ll find a number of posts on the process. Also you can go to U-Tube which also has posts with vids.
. L
Old Feb 10, 2026 | 07:24 PM
Ltngdrvr's Avatar
Ltngdrvr
Yeah, there's a large metal panel between the glovebox and head unit.
Old Feb 10, 2026 | 07:36 PM
namvet6869's Avatar
namvet6869
I understand. I've had mine out 3 times so i know the procedure. Just put things back together and forgot to connect the mic to the radio. Was hoping there was an easier way. Thanks everyone.
Old Feb 10, 2026 | 11:04 PM
Unfortunately no simple way it seems, but to get the radio out is not all that difficult, just time consuming. Good luck.
To radio
