LED rear letters?
Old Mar 5, 2026 | 06:19 PM
PUNISHER VETTE's Avatar
PUNISHER VETTE
Default LED rear letters?
I have a C3 that I took out the rear badge letter holes and fiberglassed the embossed corvette letters from a C5(did this so many years ago but just getting back in the project again).
Just curious if anyone seen an LED version of this? I'm not afraid to drill into each letter to feed some wires but can't seem to find any photos of anyone that has done this. It's a pretty shallow lettering so probably wouldn't work great but there's some weird LED options out there now a days.
Old Mar 5, 2026 | 09:36 PM
jdmvette's Avatar
jdmvette
Night Owl for life
never seen or heard of this. look forward to you being the first!
Old Mar 5, 2026 | 11:09 PM
CFight's Avatar
CFight
Cut them out and put a sheet of plexi and a red LED strip behind?
Old Mar 6, 2026 | 06:31 AM
hyperv6's Avatar
hyperv6
The letters look good I would forget the LED. I is something in the future you will think why did I do that. Kind of like the guys with the LED underbody lights.
Old Mar 6, 2026 | 04:10 PM
^. I would agree with this - the lettering looks
good as is.
Old Mar 6, 2026 | 04:40 PM
PUNISHER VETTE
That would probably be better than what I was thinking.
Just figured if there was a kit or some known LED option I might have opted for that but without it I have far too many other issues with the car to be inventing it lol
Old Mar 6, 2026 | 05:09 PM
DREEZZEE's Avatar
DREEZZEE
+1 for leaving the recessed letters and maybe adding different color stickers or have them hand painted
Old Mar 7, 2026 | 03:26 PM
DetroitGS's Avatar
DetroitGS
I like what you've done with the updated Corvette letters. That's pretty cool. I'd encourage to not do the cutout letters with leds.
Old Mar 8, 2026 | 07:15 AM
Tusc's Avatar
Tusc
Running Guns & Moonshine
Or....
Cut the letters out entirely. All the way through the panel. Mount a flat panel behind it. Surround that with LED strips. Place a mirror on the opposite side of the panel. Boom!
Old Mar 15, 2026 | 11:06 PM
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
Originally Posted by Tusc
Or....
This works except for the "O" which would need the center of it secured to the panel
If you were feeling extra handy, here's what I would do:
1) Get a 1/4" thick sheet of acrylic. Paint the backside of the acrylic the same color as the car bumper.
2) Cut ouf the letters making sure to save the inside of the "O"
3) Remove the bumper or this section of the bumper so it lays flat. Lay it on top of the non-painted side of the acrylic. Secure the acrylic to the backside of the section of fiberglas
4) With the insert of the "O" secured, pour clear epoxy into the empty gaps. It should adhere to the acrylic.
5) Sand down until flat. The letters will appear clear but have the backing the color of the car. When LED lights are applied to the side of the acrylic, the word "Corvette" will illuminate based on the body color.
6) For painting, you will need to cut a stencil to block the paint. You can use clear vinyl then gently cut out the letters leaving the epoxy clear protected.
7) Paint as many coats as you wish, then remove the vinyl.
8) Apply clear coat and buff until smooth.
The end result will be stunning.
Old Mar 16, 2026 | 12:34 AM
Tusc's Avatar
Tusc
I vote body color behind the acrylic but red leds to match whichever aftermarket brake lights for the surround.
Also.... because red lettering at night would look kind of badass. LEDs probably need to be somewhat bright so as not to be a mild glow or to fade into nothing between your running or brake lights at night.
Old Mar 16, 2026 | 12:37 PM
Gorn Captain's Avatar
Gorn Captain
Very cool! If you can work out a way to flood light them from behind with led's then ok, but if you had only pin-point led's making strings of dots for the letters, that would look blah.
How about just get some red reflective letters cut so they shine when a car behind lights them up? Plenty of sellers on ebay have pre-cut C5 letters, just find one that will custom cut reflector vinyl set for you.
C3 with the corvette on the back end.....very very cool!.
Old Mar 16, 2026 | 05:04 PM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
I've definitely never seen a premade kit for anything like this. However, I have seen LED illuminated Corvette door sills. If you look around for some of those, you might be able to adapt them for what you're doing.
With that said, I agree that it would be better not to light the letters. If you want some contrast, there's a pretty decent selection of inserts available.
Old Mar 26, 2026 | 09:54 AM
Diydoidothisc5's Avatar
Diydoidothisc5
Haven't seen them before bur that would be cool
Old May 27, 2026 | 01:11 PM
Popboy129's Avatar
Popboy129
Cruising
Default Challenge accepted and finished lol
Challenge accepted and finished last night! Been delaying it for a year off and on as I was nervous on using the dremel on it but happy with the finished product! Might still do red to match the brake lights then wire it to the brakes so it lights up! But yeah here it is!
Old May 27, 2026 | 01:16 PM
Tusc's Avatar
Tusc
Wow!
OK we definitely need some high res day and night shots of this. Looks great so far.
Old May 27, 2026 | 01:24 PM
TheRadioFlyer
Supporting Vendor
Wow!
OK we definitely need some high rest day and night shots of this. Looks great so far.
Agree. I would love to see the backside as well and the process you used
__________________
George Argel
President
Sharplightinnovations.com
(Formerly Radioflyer Innovations LLC)
To LED rear letters?
Old May 27, 2026 | 02:13 PM
MWWarlord's Avatar
MWWarlord
I would definitely like to see what this looks like in the daylight. Having it light up red with the break light would be a cool idea. I'm guessing you cut out the original letters?
Old May 28, 2026 | 07:39 PM
old stingray's Avatar
old stingray
Looks great,but the tag lights are a little over powering.
Old May 28, 2026 | 10:48 PM
Popboy129's Avatar
Popboy129
Cruising
[lol thanks yeah I’ll take some more pics soon! Thanks! QUOTE=Tusc;1609668400]Wow!
OK we definitely need some high res day and night shots of this. Looks great so far.[/QUOTE]
