Exhaust
Old Mar 9, 2026 | 04:56 PM
Dobdog's Avatar
Dobdog
4th Gear
Default Exhaust
Does the Borlas S type mufflers usually hang dow a bit from stock location? Looks pretty low to me?
Old Mar 9, 2026 | 09:49 PM
Midwest19942000's Avatar
Midwest19942000
If you don’t like the tips hanging low and angle them up slightly to fit closer to the body then yes from a distance you will see a little more of the muffler hanging down from the side view of the car. At least that’s the case with the S Type II 140427.
Old Mar 10, 2026 | 01:26 AM
Dobdog's Avatar
Dobdog
4th Gear
Default muffler
Thanks have someone that wants to sell a set for a fair price ,,but in the picture it looks to hang below the body line
Old Mar 10, 2026 | 06:35 AM
hyperv6's Avatar
hyperv6
65% of the C5 aftermarket exhaust are either out of place or uneven. People too often never take the time to adjust them correctly.
Borla will twist and adjust to get the right place. Just do not get too high up or not out from under the car enough as you can damage the bumper.
Old Mar 10, 2026 | 01:28 PM
Dobdog's Avatar
Dobdog
4th Gear
Default exhaust
was looking at the set up on a ad and was looking to see if that is the case,, Pretty sure I can modify if needed , Thanks
Old Mar 26, 2026 | 03:44 PM
Diydoidothisc5's Avatar
Diydoidothisc5
Something to add. Replace your rear muffler hangers, they can cause acess sag and cause the mufflers even with adjustment to sit lower and be uneven. You can get them cheap on Amazon think I payed 55
To Exhaust
