C5 Camshaft Recommendations
Old Mar 19, 2026 | 01:47 PM
Tusc's Avatar
Tusc
Running Guns & Moonshine
Originally Posted by MWWarlord
Given that you're not looking for a performance upgrade, you don't want to lower your MPG, and you really just want a better sound, I think think some of the things mentioned above wouldn't be the best fit for you. You DEFINITELY don't want anything like a BTR stage 3. There's also no need to do a gear swap. You already have 3.15 gears, and the main reason for a gear swap would be performance, which you already said is not what you're looking for. A gear swap will have absolutely no impact on your sound.
In general, any cam that's going to create a lot of chop will have a negative impact on your gas mileage. Headers alone can definitely make a noticable difference to your sound. However, headers alone don't create chop. Also, a note regarding headers. You don't necessarily delete your AIR system. It will depend on what headers you get. Depending on where you live, you may need to keep your AIR system in order for your car to pass inspection/emissions.
Given your stated goals, if you do decide on a cam, you'll likely want something relatively mild. However, if you just want a better sound, but don't necessarily need chop, just headers will probably be your best option.
Fully agreed, and agreeing so from years of experience. I feel like the goals are at odds. Chop cam / but good mpg and no required power gain? Anything done will be an upgrade in a sense from oem, so there will be more power. But a heavy choppa cam is going to typically nix mpg because they run a lot of positive overlap and lower lsa. I totally get cam selection based on sound. I've been there at least once. But if someone has never had a snotty cam and doesn't know the trade-offs in car character.... especially if NOT chasing power (?) .... I think they might not be happy with the car and how it drives if they go that route. I like snotty cars. I've got one across town right now about to be woken up. An absolute RIPPER the way I bought it. But I'm ordering a cam by end of the week I've specifically designed to be a smooth little grind.
Gears are fun. Cams are fun. Pipes are a must. Cost per power, I always aim folks to used blower kits. But in this case.... I think the best advice above (including your own) is to talk to the tuner because they can greatly control idle to give it that chopp sound or amplify it on whichever cam is selected.
I wonder if the itch might be scratched with a good "stage 1" something with long tubes and maybe add some cutouts. The Atak is already a solid good sounding set of pipes. It can be made to sound aggressive and not be trading a lot off.
OP: First cam swap?
Old Apr 12, 2026 | 08:52 AM
odinandrota's Avatar
odinandrota
It seems like a cam like the BTR Truck Norris, or Low buck truck cam will give you that lopey idle sound, and improve torque and HP across the curve over stock. Richard Holdener has lots of good dyno videos about this.
Old Apr 12, 2026 | 01:29 PM
Mikeybratz's Avatar
Mikeybratz
Texas Speed & Performance is great and the 220R sounds like what you're after.
https://www.texas-speed.com/cat/cams...s/ls1-ls2-ls6/
Old Apr 15, 2026 | 04:19 PM
Midwayman's Avatar
Midwayman
I have this one-
https://sdparts.com/i-24138755-sdpc-...6-0l-6-2l.html
Runs on cheap ls6 behive springs. Only upside in terms of power. pulls out to 6800 with a peak just after 6k. Light lope.
Old Apr 16, 2026 | 09:12 AM
Beast's Avatar
Beast
IMO a great street cam would be the comp cams 224/230 .575 lift. Slightly larger would be a cam motion titan 4, 228/232. These cams are probably perfect my car, my car is ready for this. I already have long tube headers, 3.73 gears, and a 3200stall.
Good luck, some people say go big or go home. Most people run there cars from 2,500 RPM to 5500 RPM. Stage 4 cam is great for drag racing, but not for daily driving. Just my .02
Old Apr 16, 2026 | 10:36 AM
Tusc's Avatar
Tusc
Those are great cams each. I'm in a similar ballpark for my 427 cam, but need to call Cam Motion today to see if they can cut it on a stock they already have. They've not gotten back to me in a week.
