A/C controller
Old Mar 24, 2026 | 06:02 AM
alcoed's Avatar
alcoed
Default A/C controller
I have an a/c control that has the display lighten dim. Is it a better idea to get the oem repaired or replace it with a new ebay unit? Anybody have any experience with the aftermarket controllers?
Old Mar 24, 2026 | 07:50 AM
DDaaryl's Avatar
DDaaryl
No experience with aftermarket parts but there are many u-tube videos showing how to repair the dim lights. I have done it twice. Took me about 2 hours (3 beers) I didn't want to send mine out for repair and figured I would attempt to do it myself. C5 Corvette HVAC control issues, typically manifested as dim, intermittent, or blank displays, are commonly repaired by
resoldering eight "241" resistors on the internal circuit board, which fail due to heat cracking. This DIY fix requires removing the center console, extracting the unit, and using a soldering iron to reflow the solder
This video describes removal and repair of the unit:
Good luck!
Old Mar 24, 2026 | 04:26 PM
jcgunn's Avatar
jcgunn
I did the dim resistor fix three times on my OEM unit over the last 24 years or so and it finally gave out again. I bought a new unit from Rock Auto. 100% improvement.
Old Mar 24, 2026 | 09:09 PM
alcoed's Avatar
alcoed
Did you notice the new controller being a Chinese made?
Old Mar 25, 2026 | 10:30 AM
cdw's Avatar
cdw
did the same for my 97. worked great
Old Mar 25, 2026 | 11:09 AM
jcgunn's Avatar
jcgunn
Mexico
Old Mar 25, 2026 | 01:09 PM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
I repaired the OEM many years ago. I haven't had any issues with it since.
Old Mar 29, 2026 | 01:02 PM
Gorn Captain's Avatar
Gorn Captain
It’s a very easy fix if you can solder. I did mine and I was done in an hour, start to finish. Very satisfying repair.
Old Mar 30, 2026 | 05:46 AM
jdmvette's Avatar
jdmvette
Night Owl for life
I ordered one of those new cheap climate controllers from eBay. My OEM controller has a bunch of cracking buttons so I want to see how the aftermarket unit holds up. I'll let you know how it goes and if it is cheap chinesium garbage or if it is decent.
To A/C controller
