Shampoo engine or not?
Old Apr 3, 2026 | 11:55 AM
Cor29's Avatar
Cor29
Default Shampoo engine or not?
Getting my c5 detailed next week and wondering what the general agreement when it comes to engine bay?
full shampoo? Steam and wipe or elbow grease and rags?
Old Apr 3, 2026 | 04:21 PM
vette4fl's Avatar
vette4fl
Hose(use some good judgment around electronics), bucket of soapy water, towel. Armor-all and a couple more towels.
Old Apr 3, 2026 | 04:41 PM
USAZR1's Avatar
USAZR1
Diluted Simple Green and a couple hand towels is all I've used, in the past.
Old Apr 3, 2026 | 05:52 PM
Gorn Captain's Avatar
Gorn Captain
I saw a video of a guy spraying his with scrubbing bubbles tub cleaner. It did a pretty good job. Spray on, leave it for a few minutes and hosed it down.
I lol’d, but it’s household safe…
Old Apr 3, 2026 | 06:21 PM
helga203's Avatar
helga203
I would suggest taking some electrical diagnostic automobile classes before you start cleaning the engine bay. Its not just the water you might move a wire that's on its last leg and can cause havoc.
P.S. im not kinding.
Old Apr 3, 2026 | 06:25 PM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
I start by blowing all the loose debris and pollen out with a leaf blower. Then, I go with warm water and dawn dish soap. It cuts grease. Wipe everything down. It works great.
Old Apr 3, 2026 | 06:48 PM
Cor29's Avatar
Cor29
When i was shopping around for a c4, it was strongly advised to not spray water anywhere.
I've washed engines before but covered alternator and electrical stuff as much as I can.
Just wanted to get everyone's opinion on the matter since you guys know the c5 better than I do.
Old Apr 3, 2026 | 06:56 PM
MWWarlord's Avatar
MWWarlord
I certainly don't just take a hose to the engine bay. You just have to be smart about it though. It's fine for things to get a little wet, but you definitely don't want to soak your electronic components.
Old Apr 3, 2026 | 09:30 PM
hyperv6's Avatar
hyperv6
Better yet Dawn Power cleaner spray.
I have been using it to remove oil on a 911 engine. It has been working great.
Spray brush and then use a spray bottle with water to flush to better control it.
If it works on this engine it would work great on a LS with less crud.
Old Apr 3, 2026 | 10:51 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Old Apr 4, 2026 | 02:20 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
do you think driving down the x-way at 70mph in the rain the engine compartment stays dry ????
Old Apr 4, 2026 | 04:10 PM
Cor29's Avatar
Cor29
Not at all but it also doesn't get water pouring from the top going downwards.
Old Apr 4, 2026 | 10:42 PM
MWWarlord's Avatar
MWWarlord
My engine bay gets dirtier and wetter than most due to my hood louvers. I've never once had an issue. Granted, the car is stored in a garage, and I usually avoid the rain. However, water definitely still gets in there when I wash the car.
This time of year, I get a TON of pollen in there. As I said above, I don't hit it with a hose, but dawn and a damp towel works great. A little bit of water is fine. A lot isn't.
Old Apr 5, 2026 | 10:36 PM
C5R USA's Avatar
C5R USA
From: Ideals are peaceful...History is violent...St.Charles, MO.
C5 of Year Winner (appearance mods) 2019
St. Jude Donor '08-'09-'12 thru'22
Elbow grease and rags would be my choice....My engine has never been dirty enough to use other than old microfiber towels, and maybe simple green, usually just a squirt bottle with water...Just one less problem I have to worry about with the electronics under the hood....Even if the engine bay was a complete disaster, I'd still do it by hand...
Old Apr 6, 2026 | 10:07 AM
Missileboy's Avatar
Missileboy
After you get it clean, this product works great to make it look detailed. I spray the coil covers, intake and all of the plastic/reservoirs under the hood. Makes everything look fresh. Better than Armorall. Spray the wiper cowl too!
Open full size product Mudslinger®
Old Apr 6, 2026 | 11:33 AM
Cor29's Avatar
Cor29
Thanks.
To Shampoo engine or not?
