[Z06] Dyno Numbers?
Old Mar 1, 2003 | 10:44 PM
TomsZ06's Avatar
TomsZ06
Default Dyno Numbers?
Why are the dyno numbers so much lower than the actual 405 HP stated HP. Is there that much lost from the drivetrain in the amount of 40 to 50 HP?
Old Mar 1, 2003 | 10:53 PM
Crushinator's Avatar
Crushinator
Default Re: Dyno Numbers? (TomsZ06)
There is about a 15% drivetrain loss. The 405 horse rating is at the flywheel. The dyno numbers you hear are at the wheel. Which is where it counts. I believe most '02 and '03 dyno 360 to the wheels which is roughly 425 to the flywheel.
Old Mar 2, 2003 | 01:22 PM
01BLKZ06's Avatar
01BLKZ06
Default Re: Dyno Numbers? (Nat97GTS)
remembe, its all about the car too.
I have seen 01 Z06 dyno 350 rwhp with just an exhaust, while seeing 02 Z06's dyno 345 stock.
On average, i think 02's dyno around 350-355, or atleast from what have seen.
Old Mar 2, 2003 | 01:25 PM
TomsZ06's Avatar
TomsZ06
Default Re: Dyno Numbers? (01BLKZ06)
Does anybody know what the 03 Cobra's dyno at? Curious to know if they suffer the same HP drivetrain loss as the Z06.
Old Mar 6, 2003 | 11:10 PM
phrogs's Avatar
phrogs
Veteran: Marine Corps
FWIW my 2002 made 356 at the rear wheels totaly stock! :thumbs:
johnny
Old Mar 7, 2003 | 01:58 PM
Mitch Alsup's Avatar
Mitch Alsup
The factory measures the engine output at the back of the engine with all ancilaries SAE HP(water pump, AC, Power steering, CATs, manifolds, muflers,...) or without any of the ancillaries Goss HP (not used since the late 1960's). However, that rolloing wheel dyno measures the ouptut after the clutch, transmission, drive shaft, differential, drive shafts, hub, and wheels. Each of these things looses tiny amounts of energy (that why the get warm while driving around). It is generally agreed that manual tranny drive-lines transmit 85% of the engin power to the rear wheels (15% loss) and autos loose 20%.
Old Mar 7, 2003 | 02:11 PM
RussBt's Avatar
RussBt
From: Admit Nothing, Deny Everything, Make Counter Accusations.
2002 Z06, factory stock, 1000 miles.
Click image for a larger view
Old Mar 7, 2003 | 05:29 PM
Z06_2002's Avatar
Z06_2002
Stock Cobra's seem to dyno'ing at around 360 SAE but then of course they are a good 600 lbs heavier than the Z.
:cheers:
To Dyno Numbers?
