[Z06] Removing emblems/decals
Old Mar 12, 2003 | 01:22 AM
painexpert's Avatar
painexpert
Default Removing emblems/decals
I think that the 50th anniversary "emblems" and ZO6 metal emblems on the exterior of the car look OK but I wanted to remove them.I did so with a hair dryer and some adhesive remover and then I polished the areas underneath with "Liquid Glass".The reason for this post is to inform others who wish to do this to refrain from removing the emblem in the front/nose of the car.There are two prongs on the back of the emblem that fit through two holes in this area of the car.Once I lifted the edge and saw this I quickly pushed the emblem back down and all is fine.This is just my preference for a cleaner look.
[Modified by painexpert, 10:24 PM 3/11/2003]
Old Mar 12, 2003 | 01:48 AM
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
Default Re: Removing emblems/decals (painexpert)
So the Z06 emblems on the side of the car are just double sided taped on? :confused: This is good to know. Thanks. :cheers:
Old Mar 12, 2003 | 01:52 AM
kh24's Avatar
kh24
Thats good to know cause one of my Z06 badges was placed on uneven and i'd like to fix it one day. :cheers:
Old Mar 12, 2003 | 11:13 AM
painexpert's Avatar
painexpert
Default Re: Removing emblems/decals (kh24)
It is not double sided tape.The emblems(front and rear are rubber emblems and sides are metal).The emblems backing are rubber and then adhesive is applied to the back of the rubber and then placed on the car.If you wanted to remove the emblems I believe that you would have to replace them with new ones if you then wanted to put them back on the car.
Old Mar 12, 2003 | 01:01 PM
Z06 THIS's Avatar
Z06 THIS
I did this a while back as i also didnt like the badges on my '01 cause they were black...( on a Millennium Yellow car ) and i also figured out there were holes were the front emblem goes...so i had to push the emblem back down as well... :rolleyes:
This i though was a good idea for me because i like the sleek look of no emblems...but too bad there are holes underneath the front badges
-Keith :jester
Old Mar 12, 2003 | 02:26 PM
VNAMVET's Avatar
VNAMVET
Veteran: Marine Corps
Default Re: Removing emblems/decals (Z06 THIS)
If you pull the front emblem off, I wonder if you can push the new emblem back in those holes?
Old Mar 12, 2003 | 09:16 PM
painexpert's Avatar
painexpert
Default Re: Removing emblems/decals (VNAMVET)
Yes.If you got a new emblem it easily goes right back into the two holes like new!
Old Mar 13, 2003 | 12:48 AM
Aslan's Avatar
Aslan
Cruise-In II Veteran
Oh yeah totally! I want to be the first person on my block to have a Corvette Z06 "Type R"
:eek:
-Alex
Old Mar 13, 2003 | 09:10 AM
levettegrl's Avatar
levettegrl
Cruise-In IV Veteran
you can remove the emblems-just need something to put in place of them! I took mine off and put chrome C5 emblems on from a corvette vendor
Old Mar 13, 2003 | 10:57 AM
painexpert's Avatar
painexpert
Default Re: Removing emblems/decals (levettegrl)
From what vendor did you get the new emblem?
Old Mar 13, 2003 | 03:51 PM
levettegrl's Avatar
levettegrl
they are not a vendor here so I can't type it but you can email me.
they are located in BG, KY and are at most NCM events
Old Mar 13, 2003 | 04:23 PM
J-Rod's Avatar
J-Rod
My front emblem is goofed up (from the factory) I have a new emblem to replace it. I noticed the tab and wondered if there were speed nuts behind it. If so, you'd have to pull the nose, or the bottom cover. So, is it my understanding that it simply has the tabs and nothing else?
Old Mar 13, 2003 | 08:17 PM
levettegrl's Avatar
levettegrl
Default Re: Removing emblems/decals (J-Rod)
when they took mine off all they used was some dental floss and wax afterward
Old Mar 14, 2003 | 10:19 AM
painexpert's Avatar
painexpert
Just pull it off.There are no connecting nuts underneath.
Old Mar 16, 2003 | 11:55 PM
TIKTGTR's Avatar
TIKTGTR
Ecklers has the chrome flags for 60 bucks!! :cheers:
To Removing emblems/decals
