[Z06] G-Tech
Old Mar 21, 2003 | 01:15 PM
TLM's Avatar
TLM
Default G-Tech
How accurate are they? Are they worth the money?
Thanks,
:confused: :confused:
Old Mar 22, 2003 | 05:28 AM
Shylor's Avatar
Shylor
Default Re: G-Tech (TLM)
Very for what you pay for the unit.
Old Mar 22, 2003 | 09:31 AM
GaryZ06's Avatar
GaryZ06
I have both units(pro & comp) and they are very accurate if set up correctly.
Old Mar 24, 2003 | 07:17 AM
Richy's Avatar
Richy
Default Re: G-Tech (GaryZ06)
Gary,
What does "set up correctly" mean?
Old Mar 28, 2003 | 12:08 AM
vrumvrum's Avatar
vrumvrum
Default Re: G-Tech (Richy)
I just had to make certain it was level. I was very surprised at how close to factory specs my GTech was. I was a bit disappointed in HP readings until I went back to the instruction book and discovered that the GTech will also measure how much HP is required to push the car through the air. Astationary dyno doesn't. I was getting about 285 RWHP for my stock C5 0-60 5.2secs 1/4 mile 102 @ 13.7
Old Mar 28, 2003 | 07:03 AM
Timz06's Avatar
Timz06
Default Re: G-Tech (vrumvrum)
The 0-60 works well, and 1/4 time, but the trap speed will not match what you get at the track.
Old Mar 28, 2003 | 01:06 PM
vrumvrum's Avatar
vrumvrum
Default Re: G-Tech (Timz06)
I lent mine to a friend so I don't have the instructions, but I think the trap speed issue was related to the track measuring a certain distance from the end up to the end, while the Gtech gives instant speed at the end. I've never compared the difference between track and Gtech, I'd be interested in knowing what the average difference would be. :)
Old Mar 28, 2003 | 01:22 PM
RussBt's Avatar
RussBt
From: Admit Nothing, Deny Everything, Make Counter Accusations.
I have one and I used it in my old C4 a bunch of times while at the track. ET was about .2 off and it always read about 3 MPH too fast. The results I got with it were consistent.
Old Mar 30, 2003 | 09:16 AM
GaryZ06's Avatar
GaryZ06
The set up on the Pro unit is just make sure the unit is level,straight and on tight.On the Comp there is a procedure to perform to set it up internally.The MPH is not off but actually very accurate.It reads the MPH differently than the track.The track averages the last 66 ft and the G-tech's mph is at the exact end of the 1/4
Old Apr 16, 2003 | 04:34 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
Dumb question time...
How does the GTech know you've run 1/4 mile?
Do you have to press any buttons or anything at the end of the run?
To G-Tech
