[Z06] Problem with the Z06...need HELP!
Old May 22, 2003 | 01:07 PM
TT BD's Avatar
TT BD
Default Problem with the Z06...need HELP!
Guys,
I have a Zo6. Please read this chain of events and help me come up with a diagnosis of the problem.
1. Had just taken a 40 minute trip. Stopped to get gas. When I went to start the car, the entire dash was out (instrument cluster, radio, and AC...all shut down) as well as the engine and power seats!...After a few turns of the key, the car eventually restarted, but instruments didn't come back. I drove it for about a 1/4 and the engine shuts down again. Finally got it going again and went home.
2. Next day, as I pulled in to get gas (driving alot), the dash went out again, but engine ran.
Any help would be GREATLY appreciated! :banghead:
Old May 22, 2003 | 01:16 PM
Vegasr's Avatar
Vegasr
Default Re: Problem with the Z06...need HELP! (TT BD)
Well, sound like you need to stay away from those gas stations :lol:
Have you called the dealer yet? Takening it in would be my first place to start, don't hesitate either. :flag
Old May 22, 2003 | 01:33 PM
TT BD's Avatar
TT BD
Well, thats were the problem lies...they have no frickin clue what the problem could be!!!
Old May 22, 2003 | 02:02 PM
Scruffy's Avatar
Scruffy
Sounds like you should have set some codes. Turn the key to the on position, Hold down the "Fuel" button on the DIC, and as you're holding it down press the "Options" button on the DIC (three or four?) times quickly and a sequence displaying any codes set will begin. Write down the codes and look them up. I belive there is a description of what the codes mean somewhere on this site. - Good luck.
Old May 22, 2003 | 02:52 PM
Tom Steele's Avatar
Tom Steele
Computer problem almost for sure.
You could pull up the codes. Do a search for the procedure to pull up the computer codes here and try that.
But I'd take it to the dealer and tell them what happened and have them hook it up and see what the problem is - PROBABLY a bad connection somewhere in the computer.
Check your battery too - is it leaking? If it is - or has, it leaks right on the computer wiring and trashes it.
Old May 22, 2003 | 04:01 PM
TT BD's Avatar
TT BD
Default Re: Problem with the Z06...need HELP! (Tom Steele)
Apparently, the dealership said the codes came back clean. :confused:
Old May 22, 2003 | 04:35 PM
jackmott's Avatar
jackmott
tell them to either give you a new z06, or give you a free loaner until they figure it out man.
its their problem, and they have tech lines they can call at chevy if they are clueless. its not your job to fix it.
Old May 22, 2003 | 04:43 PM
Crushinator's Avatar
Crushinator
Default Re: Problem with the Z06...need HELP! (jackmott)
:iagree: They should be able to give you some kind of an answer. Maybe no right away, but eventually they should be able to figure it out.
Old May 22, 2003 | 06:35 PM
JACSZ06's Avatar
JACSZ06
Default Re: Problem with the Z06...need HELP! (Nat02Z06)
I agree with the above statements. Don't let them get away with saying they don't know anything because there are no codes being thrown and by the way here's your car back. Tell them you want to leave it and get a loaner. Don't stop pressing them until they fix the problem. If they do a temporary fix you may end up with something wrong after your warranty is up and it'll probably cost an arm and a leg.
Old May 22, 2003 | 07:54 PM
rwd's Avatar
rwd
Possible switch or grounding problems? I've heard of grounding issues doing similar things.
Old May 22, 2003 | 11:36 PM
Piranha's Avatar
Piranha
Possible cause:
This is a quote from the April meeting of my vette club.
"B. The second item was the matter of the C5 battery. The Delco battery has a history of having the terminal bolts being too long from the factory. These can pierce the plastic battery case and cause an acid leak onto the computer. We have surfaced this scenario previously and cautions owners to have their battery checked to make sure they are not leaking onto the computer. Keep an eye on the positive side of the battery. Take your vehicle to a trusted Chevrolet dealer or someone you trust and don’t let insurance companies bully you into otherwise.
Just a possibility. :confused:
Old May 23, 2003 | 08:21 AM
Highroller's Avatar
Highroller
Not if your working with the dealers in CT :U :U
Old May 23, 2003 | 09:19 AM
Mover's Avatar
Mover
Default Re: Problem with the Z06...need HELP! (Highroller)
Isn't C4C5 mechanic around there somewhere?
Old May 23, 2003 | 09:21 AM
69L79's Avatar
69L79
From: Hamilton Square NJ, Ocean City N. J. Key Biscayne Fla.
Default Re: Problem with the Z06...need HELP! (BLKZO6)
He posts on the "other" Forum. :(
Save the WAVE!!
Old May 26, 2003 | 05:19 PM
stingray454's Avatar
stingray454
Sounds like an electrical grounding problem. There have been known issues with loose ground wires on C5's. I forgot where the usual spots are to look, but have your dealer check all the TSB's for electrical grounding issues.
Old May 27, 2003 | 12:30 PM
jerryv's Avatar
jerryv
Default Re: Problem with the Z06...need HELP! (stingray454)
Another vote for a possible ground problem. Any time you see failures in apparently unrelated systems, a ground problem is a good guess.
Old May 27, 2003 | 11:03 PM
pk2401's Avatar
pk2401
St. Jude Contributor
You should definately leave it at the dealership, and ot drive it 'til it is fixed. You never know, you can have the same problem going 70 on the freeway, then you will be in deep poopie.
To Problem with the Z06...need HELP!
