[Z06] 335/30/18s
Old Jun 3, 2003 | 07:04 PM
Trick's Avatar
Trick
Default 335/30/18s
Are they a good fit for the rear Z rim? I don't mean, "Will they fit?" Are they a good fit?
Old Jun 3, 2003 | 07:25 PM
ixlr8's Avatar
ixlr8
Default Re: 335/30/18s (Trick)
Yes definitely a good fit but you need to get the Michelin Pilot Sport 335/30/18 if it is a BFG it probably won't fit because the Pilots are not a true 335 they are probably like a 315 or 325. Its kind of like when you buy a pair of Nikes and they fit a little tighter in the same size as say Reebok
Old Jun 3, 2003 | 09:36 PM
Z06TheKid's Avatar
Z06TheKid
Default Re: 335/30/18s (ixlr8)
:withstupid:
Old Jun 5, 2003 | 12:17 PM
ixlr8's Avatar
ixlr8
Default Re: 335/30/18s (EBZ06EB)
ttt
Old Jun 5, 2003 | 08:23 PM
ixlr8's Avatar
ixlr8
ttt
Old Jun 7, 2003 | 10:19 AM
badddrx7's Avatar
badddrx7
What does ttt mean ? :confused:
Old Jun 7, 2003 | 01:43 PM
NEPTUNEBILL's Avatar
NEPTUNEBILL
got the pilots on my ccw's on 11.5" rims and they fit great, I'm not sure how well they will fit on stock z wheels, I am going to look for a comparable size bfg for my next tires, they may have to be 315's or 325's to fit without tubbing I don't think a bfg 335 would fit without rubbing, I know the bfg 295 is an inch wider than the same size pilot.
Old Jun 7, 2003 | 03:42 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
Default Re: 335/30/18s (badddrx7)
ttt = to the top
it brings the post to the top of the listed posts :D
:cheers:
Old Jun 7, 2003 | 04:25 PM
ixlr8's Avatar
ixlr8
Default Re: 335/30/18s (NEPTUNEBILL)
Yes BFG's are a bigger tire than the Pilots that is why they fit so well on the 10.5 inch rim.
Old Jun 7, 2003 | 05:37 PM
NEPTUNEBILL
What widths do they have in the kd's besides 295 I would love to compare tread width against the pilots to see how big a kd I could fit on the 11.5's.
Old Jun 8, 2003 | 10:44 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
KDs stop at 295 for 18s :nonod: Sure wish they'd tool up for 300+ 18s :yesnod: :yesnod:
joel(Bink) :cheers: :steering:
Old Jun 9, 2003 | 02:19 PM
racewheel's Avatar
0racewheel
Former Vendor
kumho 295 35 18's are almost an inch wider than the pilots and fit nicely on a 11.5 wheel
john
Old Jun 9, 2003 | 04:26 PM
NEPTUNEBILL
Default Re: 335/30/18s (binksZ06)
I heard that, a kd 315 should be the same actual width as the pilot 335, fit the ccw's perfectly and have twice the traction
To 335/30/18s
