[Z06] Shift lights?
Old Jul 1, 2003 | 08:03 PM
TeamSpeed's Avatar
TeamSpeed
Default Shift lights?
I tried a search on this and only found limited info on this. I want basically an LED shift light that is the size of a pen, or close to it. What brands install the easiest and are pretty nice to work with? Do I have to locate a wire under the dash or should I go directly to some wire off the computer connectors?
I am not even sure how to get to the computer on the vette, my Z28's PCM was located right off the firewall and was easy to access.
Any ideas on this topic? It would be neat if somebody made a module that would flash the HUD when it was time to shift, pretty stealth!
Old Jul 1, 2003 | 09:16 PM
wamara's Avatar
wamara
Cruise-In II Veteran
Default Re: Shift lights? (TeamSpeed)
Actually, your HUD does have a shift light, but it doesn't stand out enough to be easily noticeable in your peripheral vision. Try a search, as they have been mentioned regularly, for the Raptor and Harlan shiftlights, which sound like the style you're after, although they're thicker than a pencil. Harlan has gotten some bad press for poor service, however. Good luck
Old Jul 1, 2003 | 10:23 PM
TeamSpeed's Avatar
TeamSpeed
Default Re: Shift lights? (wamara)
I did a search for shiftlight, one word, and found the installation pics and which wire to use. Thanks! Ordered a black w/yellow LEDs from raptor!
Old Jul 1, 2003 | 11:41 PM
minivette's Avatar
minivette
http://www.zee-oh-six.com/install_pa...ht_install.htm
Old Jul 2, 2003 | 11:05 AM
TeamSpeed's Avatar
TeamSpeed
Default Re: Shift lights? (minivette)
That's the link I found! Thanks again.
Old Jul 3, 2003 | 08:54 AM
LC's Avatar
LC
I have the Raptor installed .. up next to the sun visor... very good position.. can't help but to see it when you approch the red line.
Old Jul 3, 2003 | 06:50 PM
minivette's Avatar
minivette
no problem. I was the one who actually did that write up I posted. If you have any questions, feel free to shoot me an email.
Old Jul 4, 2003 | 11:29 PM
georges03zo6's Avatar
georges03zo6
Nice write up man. I have been dying to install my light for 6 months and finally got it done a few days ago. :party:
Old Jul 6, 2003 | 12:23 PM
TeamSpeed's Avatar
TeamSpeed
Default Re: Shift lights? (georges03zo6)
I was wondering if anyone has followed the white wire from the PCM into the car either physically, or via the service manuals? It would seem easier to access the wire from within the car then to jack the car up, pull the wheel off, reset the PCM by disconnecting the battery, then run a wire thru the firewall grommet. Just wondering. If I go the full route, I may run a continuity check on possible wires to find the right one just to help others out in the future.
Old Jul 7, 2003 | 01:09 AM
Tracy's Avatar
Tracy
TeamSpeed---That's a good thought. If it's the tach wire, shouldn't it be going someplace INSIDE the car....like to the passenger floorboards or to the intrument cluster? If I wasn't so lazy AND if I had ordered a Raptor, I'd open my service manuals and find out!
Old Jul 7, 2003 | 11:38 PM
minivette's Avatar
minivette
Default Re: Shift lights? (Tracy)
Yes, it is in the mass of wires in the passenger footwell. I was not confident on finding it so I went to the source, the PCM.
Old Jul 7, 2003 | 11:58 PM
rodney@rpmtransmissions's Avatar
0rodney@rpmtransmissions
Former Vendor
Any luck on finding the wire in the inside of the car,my shift light will be here tomorrow. :confused:
Old Jul 8, 2003 | 03:17 AM
Shylor's Avatar
Shylor
I never noticed it on mine. Are you sure the HUD has a shift light?
Old Jul 8, 2003 | 09:02 AM
Tracy's Avatar
Tracy
Default Re: Shift lights? (Shylor)
Shylor--That's the point....it's hard to notice!!! You have to have the tach portion of the HUD activated, and zing the motor up there, and you'll see the shift light. Of course, you could look in your owners manual to see where it's located in the display.
Old Jul 8, 2003 | 08:31 PM
TeamSpeed's Avatar
TeamSpeed
I have never seen my shift light come on in my Z? Maybe I don't have it in the correct mode, I will have to check it out.
I haven't done anything with the install of the shift light yet. Since I do not know which wire in the passenger footwell is the tach, I will have to do a little research for the benefit of the vette community when I have everything out!
Old Jul 9, 2003 | 12:48 AM
Tracy's Avatar
Tracy
Yeah, you need to be in "tachometer mode". You can have every other display on (and you'll never see the shift light!!) or go to the tach only or tach and speed modes, and that gives a better picture. The shift light gets lost in all the other silly displays--gas, water temp, oil temp, etc etc etc.
Old Jul 9, 2003 | 07:11 PM
03QuicksilverZ06's Avatar
03QuicksilverZ06
Thanks Tracy, good info, I will use the tach mode only from now on, as long as the radar detector is hooked up :jester
To Shift lights?
Old Jul 10, 2003 | 12:33 AM
Tracy's Avatar
Tracy
Default Re: Shift lights? (03QuicksilverZ06)
Tach only will show you the shift light, but tach/mph is probably what you'll prefer.
As for the radar detector...it should ALWAYS be on, regardless what your tach is doing!!!
Old Jul 10, 2003 | 09:14 PM
Teddy98Z28M6's Avatar
Teddy98Z28M6
I have a red Harlan shift light in my Z28 and used a blue Harlan shift light in my Z06.
The upside down main computer on the C5's is behind the passenger side wheel well, below the battery. There’s a rubber grommet through the firewall where you can run the wire. I have also tried to trace the white tach wire, but it’s runs into a big loom of wires, so pretty much disappear from there. You can see in the picture below where I tapped the tach wire.
Old Jul 10, 2003 | 09:24 PM
Teddy98Z28M6
Default Re: Shift lights? (Teddy98Z28M6)
I like how compact the Harlan shift light is. Mine is mounted here.
