[Z06] Operating temperatures
Old Jul 20, 2003 | 07:05 PM
AR's Avatar
AR
Default Operating temperatures
Hello
I am somewhat new to Vettes and Z06s. I just finished doing a low speed track event. 90mph or so. Nothing too punishing. There other Z06s there. My temp ran max 223 and the other owners said they ran lowere. Should I be concerned and should I get the lower temp set thermostat. Thanks for your advice
Old Jul 20, 2003 | 08:04 PM
SQEZN BI's Avatar
SQEZN BI
Default Re: Operating temperatures (AR)
My z was getting up to 230 with the ac on, I put in a 160 thermostat and it still got upv to 220. I noticed that the high speed fan mode didnt come on until it got up to around 220. I added a fan controller and now i dont get above about 210 max on a super hot california day with the ac on. If you do the thermostat yourself, which is super easy, you might be able to find someone with one of the many computer programmers and use it to lower your fan turn on temperatures. I is a good idea to lower your temp synthetic oil starts to take a dump at around 250. Although heat makes horsepower I would rather get some extra engine life. Peace out.
Old Jul 20, 2003 | 08:17 PM
Airwolf's Avatar
Airwolf
From: ********************* Florida's Space Coast *********************
Default Re: Operating temperatures (SQEZN BI)
Synthetic oil can handle temps above 300 F without any problems according to both Amsoil and Mobil 1 websites. I have seen my car oil temp at 230+ and figured I was well below the "problem" temp.
Where did you hear 250? My curiosity is peeked!
Old Jul 21, 2003 | 02:53 AM
SQEZN BI's Avatar
SQEZN BI
Actually, this is chevrons synthetic oil and this was a few years ago. We know that mobil 1 is good oil aparently much better than the chevron oil of the past. Ive seen my oil temp up to 230 too. Actually would like to get an oil cooler but the prices Ive seen are pretty steep. :chevy
Old Jul 21, 2003 | 11:18 AM
woosch's Avatar
woosch
Just got back from running at VIR, saw oil temps of 304 :eek: and coolant of 250+ :eek: :eek:
Got to figure out a way to cool this thing better. Guess it's time for an oil cooler and fan adjustment.
Old Jul 21, 2003 | 01:45 PM
EasyMoney's Avatar
EasyMoney
Navigator
Synthetic oil's such as Mobile 1 are good for over 400 degrees before oil starts to break down.
Old Jul 21, 2003 | 02:04 PM
atoyf's Avatar
atoyf
you are perfectly fine with those temps, do not need do anything
Old Jul 21, 2003 | 02:06 PM
SWCDuke's Avatar
SWCDuke
Default Re: Operating temperatures (EasyMoney)
160 thermostats are a waste of time and money and overcool the engine in cold weather. The thermostat estabalishes the LOWEST engine operating temperature. The highest temperature is a function of vehicle speed, engine load, and ambient temperature. Since the fans don't engage until 228 with the AC off running 220 is normal, acceptable, and actually preferential.
All engines run with lower piston/ring drag at high jacket temps and high jacket temps also yield better thermal efficiency which means more power, and this is particularly the case with aluminum engines that transfer heat more readily from the combustion chamber to the cooling jacket.
With a 50/50 mix of Dexcool and water the boiling temp is 265 minimum, so you've still got lots of margin at 220-230.
The biggest problem with the C5 operating temp is high oil temps at the track - both then engine, gearbox, and axle. Though 300 degrees may be considered acceptable with synthetic lubricants, a lot of high temp time is going to take a toll on elastomeric materials such as seals and gaskets.
Duke
Old Jul 21, 2003 | 05:59 PM
AR's Avatar
AR
Default Re: Operating temperatures (SWCDuke)
Duke
thanks for the scholarly response. I have been well aware of the trannies running hot and from my previous experience with porsches, I am well versed in oil temps and pressures. I have been doing mostly autocross type stuff recently. I think if I start venturing out on the longer tracks I may get the tranny cooler and the two in one radiator/oil cooler that Doug Rippie has. For now I think I am going to go to the dealer to reprogram the fan on point to a lower temp like 190 or so
thanks
AR
Old Jul 21, 2003 | 06:24 PM
silverz06vette's Avatar
silverz06vette
Default Re: Operating temperatures (woosch)
With a fan controller/stock stat I ran about 225* water the few times I checked it at the same event. Wonder if a 178* stat is needed or necessary? I think I saw about 298* once on the oil.
For my last session I ran about 20 mins then started to run out of gas. (started with 3/8 tank) I went into the pits and they said I could come back in a few mins and run with the next group. So I got some gas, parked on pit road for 5 mins with the hood open. Got some water and then returned to the track. In 5-6 laps I got the "high trans temp" lite on the dic. Hitting the reset button I had a temp of 272* I took it in and called it a day. That was the only time I got the trans temp warning the entire w/e.
Old Jul 25, 2003 | 01:13 AM
SQEZN BI's Avatar
SQEZN BI
I see where the confusion was on my previous response when i refered to the temp of 250+ i was refering to the engine temp not the actual oil temp which is higher. my bad . :smash: :smash:
To Operating temperatures
