[Z06] Trunk lid pop-up
Old Jul 25, 2003 | 03:09 PM
GAVET's Avatar
GAVET
Default Trunk lid pop-up
Mine won't go up much past grab it with your fingernail high, dealer took a swing at it and they can't do much better. (02 Z06) Anybody got a cure?
[Modified by GAVET, 3:09 PM 7/25/2003]
Old Jul 25, 2003 | 03:32 PM
Scott03Z06's Avatar
Scott03Z06
Default Re: Trunk lid pop-up (GAVET)
The latch spring should be able to lift the trunk door enough to slide your fingers inside and open it the rest of the way. If this does not happen, check to see if the spring inside the latch assembly is missing. If it's not missing, have a service mechanic look at it and try to adjust it. If it can't be adjusted, have the latch assembly replaced.
Old Jul 25, 2003 | 03:35 PM
inferno's Avatar
inferno
Default Re: Trunk lid pop-up (lt4vette)
or roll the windows up, release the trunk and shut the doors .. it pops right up :)
[Modified by inferno, 2:35 PM 7/25/2003]
Old Jul 25, 2003 | 04:06 PM
Z11409's Avatar
Z11409
Lubricate hinges-on both sides of body opening are two rubber bumpers--turn them out at least one full term
Old Jul 25, 2003 | 04:11 PM
gmblack3's Avatar
gmblack3
Default Re: Trunk lid pop-up (Z11409)
Pull the carpet back from around the lock mech area. Spray a little WD-40 or the lube of your choice. Good as new. This happens alot in the colder weather months.
Old Jul 25, 2003 | 04:56 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
Default Re: Trunk lid pop-up (gmblack3)
:iagree: Try a little WD 40 or similar lubricant. It will do the trick. Just need to repeat lubrication ever so often to keep it functioning correctly. Mine has the same problem. It's time for the WD 40 treatment again.
Old Jul 25, 2003 | 05:24 PM
GAVET's Avatar
GAVET
Default Re: Trunk lid pop-up (Z06ufgrad2002)
Thanks, great tips, I am on my way to try them
Old Jul 25, 2003 | 10:11 PM
Sandy S's Avatar
Sandy S
Make sure the weather strip seal is not sticking to the trunk lid. Mine sticks some times after I wash it.
The whole thing seems like a weak design but it it is really light weight and that is the real point anyway isn't it.
Old Jul 25, 2003 | 10:31 PM
OhNiner's Avatar
OhNiner
Default Re: Trunk lid pop-up (Sandy S)
Mine is the same.
Old Jul 26, 2003 | 12:54 AM
Z06Plasticfantastic's Avatar
Z06Plasticfantastic
Open up your trunk and take a look on each respective side of the lid. There should be a spring loaded post with a plastic hexagonal "****" on each side of the trunk.
Try backing each side out about 1/4 turn. This should give more spring pressure to the trunk lid and pop the lid open more positively. Don't get too carried away with the adustments or the trunk will become hard to close. Make sure you back each side out about the same. If that doesn't work, go to the dealer, there were some cars which had bad latches and/or bad actuators.
Old Jul 26, 2003 | 02:46 AM
Not Red Rob's Avatar
Not Red Rob
2023 C4 of the Year Winner - Modified
my '99 FRC had the same problem & on mine I sprayed WD40 on the gas shock shafts near the end. The factory had painted the ends of the shaft and when closed the the shocks compress more than when painted, this painted section hangs on the tip gas shock.
Mine has been working great ever since.
Thanks,
Rob :jester
To Trunk lid pop-up
