[Z06] grinding in reverse?
Old Aug 4, 2003 | 05:19 PM
joe03z06's Avatar
joe03z06
Default grinding in reverse?
putting my car in reverse i get a grind every time, anyone have this problem? worried about all the joy riding of the dealership employees
Old Aug 4, 2003 | 05:26 PM
gmblack3's Avatar
gmblack3
Default Re: grinding in reverse? (joe03z06)
sounds like a trip to the dealer for reverse synchro.
Old Aug 5, 2003 | 08:33 AM
Scott03Z06's Avatar
Scott03Z06
Default Re: grinding in reverse? (gmblack3)
Is reverse syncronized in the T-56? I don't think it is?
Try placing the transmission in a forward gear (1st-6th) before placing it in reverse. It should not grind provided that the car isn't moving or the clutch is engaged.
Old Aug 5, 2003 | 10:10 AM
CAPN17's Avatar
CAPN17
Default Re: grinding in reverse? (lt4vette)
It should not grind going into reverse if you are stopped. Grinding when stopped, car and trans, is a sign of a problem that should be loooked at before you can not back up at all.
To grinding in reverse?
