[Z06] LS6 heads
Old Aug 5, 2003 | 01:23 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Default LS6 heads
I understand the 02+ Z06 have lighter valves than the 01s. How do you tell the 2 apart? Also what are the cast #s for the various LS6 heads?
Thanks,
[Modified by 93Polo, 1:23 PM 8/5/2003]
Old Aug 7, 2003 | 03:20 PM
Mitch Alsup's Avatar
Mitch Alsup
Default Re: LS6 heads (93Polo)
"How do you tell the 2 apart? "
You could cut them open and see which ones have the drilled stem,
or
you could put them on a tripple beam scale and see which is heavier.
Was this a trick question?
Old Aug 7, 2003 | 04:05 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Default Re: LS6 heads (Mitch Alsup)
I found a set of heads for sale LS6 heads with valves no springs etc.
I wanted to know if they were 01 or 02+ valves if there is a way without weighing them.
I also wanted the casting #s for LS6 heads but I have searched and found the answer to that one.
Old Aug 7, 2003 | 08:39 PM
SpinMonster's Avatar
SpinMonster
On the combustion chamber side there is an 02 stamped into the head.
To LS6 heads
