[Z06] Drivetrain ?
Old Sep 21, 2003 | 05:50 PM
Green Goblin's Avatar
Green Goblin
Default Drivetrain or possible Tranny ?
When I am going down a hill or coasting, if I am barely in the throttle, you can feel the car sort of jerk/lunge, or even somewhat surge. I noticed this before on my WS6, but in the Z06 I feel it more. It only happens when moderate throttle is applied.. Any help??? Normal??? :banghead:
[Modified by Green Goblin, 5:51 PM 9/21/2003]
Old Sep 22, 2003 | 01:08 PM
Green Goblin
Default Re: Drivetrain or possible Tranny ? (Green Goblin)
Please...TTT
Old Sep 22, 2003 | 01:16 PM
woosch's Avatar
woosch
Sounds like you need to make it to an event so we can check out your car for you :rofl:
Not sure what you mean.... It sounds like the normal "compression braking" where the engine's compression/rpm is slowing the car down.
Old Sep 22, 2003 | 02:46 PM
ScottZ's Avatar
ScottZ
At what speed and in what gear? My guess is that woosh is right but hard to say without the other info. If you are coasting in a low gear at high speed, then I can see how this would happen.
Old Sep 22, 2003 | 04:29 PM
Green Goblin
Default Re: Drivetrain or possible Tranny ? (smwalsh)
I'm crusin in 4th ger let out to coast to a stop, realize I don't need to come to a complete stop, give it a little gas and it jerks...It really does it in any gear. It does feel like the low gear high speed "feel" though...
Old Sep 22, 2003 | 05:30 PM
ZEDohSIX's Avatar
ZEDohSIX
Could the PCM shutting down fuel in a coast situation. The transition is never completely transparent (at least for me) and I feel the slight surge when the fuel is resupplied and the motor generates a little torque.
Old Sep 23, 2003 | 09:20 AM
Green Goblin
Default Re: Drivetrain or possible Tranny ? (ZEDohSIX)
Good info to know...At least I'm not the only one... :cheers:
Old Sep 23, 2003 | 09:34 AM
ScottZ's Avatar
ScottZ
I'll try to simulate the coasting in 4th next time I have her out. May be that many of us just don't notice it or are used to it as being normal. On the other hand, it could also be that I never give her just a little gas ... it's always WOT :lolg:
To Drivetrain ?
