[Z06] Breathless shifter.
Old Oct 1, 2003 | 06:56 PM
Leroy Amy's Avatar
Leroy Amy
Default Breathless shifter.
Looking to up grade shifter,need pros and cons on Breathless VS Hurst
Old Oct 1, 2003 | 08:55 PM
ValleyZ06's Avatar
ValleyZ06
Default Re: Breathless shifter. (Leroy Amy)
Do a search and you will get plenty of hits. I have the Breathless and can't say enough about its crisp, precise and short shifts. I also love the fact that you have 16 different positions and 3 different spring loads to choose from. I use the softest springs and tried out all 16 different positions while installing it. The only complaint I had with the shifter was that it was a little loud at first, but is has gotten quieter with use. I haven't missed a shift since getting it. Hope this helps you out.
Old Oct 1, 2003 | 10:04 PM
ALLKAR's Avatar
ALLKAR
Senior Member
Cruise-In V Veteran
Default Re: Breathless shifter. (ValleyZ06)
:iagree: :thumbs:
To Breathless shifter.
