[Z06] is there any difference between????
Old Oct 6, 2003 | 11:12 AM
NJ99FRC's Avatar
NJ99FRC
From: If you can see the car behind you, your not going fast enough
Default is there any difference between????
Is there any difference between the LS6 heads from 01' and THe LS6 heads from 02? If so what is it?
Old Oct 6, 2003 | 11:21 AM
StickTail's Avatar
StickTail
Default Re: is there any difference between???? (NJ99FRC)
From what I understand the heads are the same.
The springs and valves are different though but the castings are the same.
