[Z06] A question for the powershifters
Andi
The hp argument works, but torque is THE true fundmental quantity. However, torque arguments without consideration to gearing can be rather misleading, hence the simplicity of the hp case! :)
[Modified by raj, 12:00 AM 10/17/2003]
Ric
PS; Rear end ratio is a constant.
[Modified by Power Shifter, 1:11 AM 10/17/2003]
[Modified by Power Shifter, 1:17 AM 10/17/2003]
I'd also like to note that while your tq & gearing multiplication math is correct, it's unnecessary. HP already factors in torque *and* rotational velocity, and as such does not change as it passes through the transmission. That's the beauty of looking at it from the HP side - it skips the gearing math and still gives you the same answer. Why? All the transmission & gearing does is change the proportions of the two components of the horsepower -- torque and RPM. But the HP goes in one side of the transmission and goes out the other as the same amount (barring frictional/inertial losses that are outside the scope of this discussion), and that HP figure is directly proportional to the amount of rear wheel torque you have available to accelerate the car at any given speed.
That's why you can do the shift point analysis using your ABSOLUTELY CORRECT method of tq * gear multiplication (like I did for my Maxima back in the day before I figured this out), or you can just see where HP curves intersect in the before & after gears intersect(like I did for my Supra in this example after I figured this out), and you will see that if you use both methods they will always agree as the math in the former method is redundant as the HP comparison method takes care of everything for you.
Oh, and to Power Shifter.. as I wrote this, I noticed that you replied and said that all that matters is driveshaft torque* (i.e. rear wheel torque, and finally accelerative force). That is correct. And that's what I'm talking about in this thread -- driveshaft torque is directly proportional to HORSEPOWER, not to flywheel torque..... to understand this, look at Raj's excellent example above showing why you're much better off at a higher rpm, higher hp lowre torque point in a lower gear than at peak torque in a higher gear.
*Driveshaft torque: i'm assuming you mean transmission output shaft torque, which would be driveshaft torque in any car with a conventional front-mounted transmission.... and not actaul c5 driveshaft torque that technically really is just flywheel torque..... heh.
Andi
[Modified by Andi, 12:21 AM 10/17/2003]
[Modified by Andi, 12:23 AM 10/17/2003]
Tuesday should be a very interesting night at the track.
Thanks to everyone for their insights and responses
David In Indy :cheers:
BTW, your website is neat! :cool: Didn't realize how peaky those twin turbo outputs are - quite another world from the land of big displacement! ;)
