[Z06] Z06 tire pump kit
Old Oct 14, 2003 | 10:24 PM
BQ's-02's Avatar
BQ's-02
Cruising
Default Z06 tire pump kit
When I purchased my 02', it did not have the the tire pump kit, (nothing). I guess the original owner keep it. Is it ok (while I'm waiting for my kit) to use "Fix-a-Flat" in an emergency?
Old Oct 14, 2003 | 10:41 PM
Whacked's Avatar
Whacked
Default Re: Z06 tire pump kit (BQ's-02)
in an extreme emergency....even the pump kit is pretty much useless, the stuff just makes such a mess if it comes out of the tire, not to mention it throws off the balance of the tire so try to avoid using any of that stuff....
Old Oct 14, 2003 | 10:52 PM
slong's Avatar
slong
But when you’re somewhere, and there's nothing or nobody in site, try any sealer if the hole is not too big. About "I'm Guessing" 90% of the time it is a small road hazard that gets your tire. Been off roading many times when two or three cans fixed a big tire so we could get back to the road and home.
:cheers:
[Modified by slong, 1:40 PM 10/19/2003]
Old Oct 15, 2003 | 02:05 AM
Shylor's Avatar
Shylor
I don't think I'm even going to use the GM kit and just use spare tire in a can and a tire patch kit. I'll just carry several of them as it is less weight than the GM kit.
Old Oct 15, 2003 | 02:32 PM
jerryv's Avatar
jerryv
You can get the kit from GM at wildly over-inflated prices. Or, you can get a small Campbell-Hausfeld compressor from Walmart and a can of fix-a-flat.
Old Oct 15, 2003 | 08:25 PM
Fast Lane's Avatar
Fast Lane
CI 3-4-5-6-7-8-9-10 Veteran
I've had one flat. In the parking lot I located a nail in my rear tire. I carry pliers, C5Fredrik jack, tire plug kit. I jacked it up a little, pulled the nail, put in a plug and was ready to go. Did use the OEM air pump though.
Good Luck :seeya
Old Oct 15, 2003 | 09:34 PM
Painrace's Avatar
Painrace
I had a flat on a 02. The kit did not work. I replaced the sealer to keep the car original. I would use fix-a-flat or something like that. The GM goop makes a real mess in the wheel, on the tire and on the underbody and still does not work.
I have plugged several tires with a NAPA plug gun and kit. Once the tire is heated even Goodyear can't find it.
Old Oct 16, 2003 | 08:52 PM
Shylor's Avatar
Shylor
Default Re: Z06 tire pump kit (Painrace)
What is the part number for this NAPA plug gun kit and how much does it cost?
Old Oct 16, 2003 | 10:17 PM
Painrace's Avatar
Painrace
Default Re: Z06 tire pump kit (Shylor)
The tire repair gun and plugs do not have a part number. It is made by Balkamp. It is called "Magicure Vulcanizing Plug Kit" It comes with 3/8" and 7/16" plugs. It is manufactured in Indianapolis. I will go to NAPA and see if I can get a part number for you. It says on the box "Vulcanizing plugs chemically vulcanize throughout the injury, becoming a permanent part of the tire". When the Goodyear engineers can't find it I say it has become a part of the tire.
I cannot honestly tell you you cannot find it in a street tire. I will assure you you cannot find it in a race tire once it is heated. Goodyear threatened to stop my sponsorship many years ago when the found crew members using it. The problem at a race track is when you scuff a set of tires and one of them has a punciture you fix the punciture or throw the set away. If the race association won't let you back on the track, and they won't, you are screwed. Goodyear forced us to stop doing it but we never had a race failure.
Old Oct 18, 2003 | 09:57 PM
Painrace's Avatar
Painrace
OK Guys, the kit has a NAPA part number of 710-1028. That is for the complete kit. It is called a "Balkamp" I don't know what that means but it is the best tire repair for a puncture I have ever seen. It will not work for a cut or sidewall problem. Good luck.
Old Oct 19, 2003 | 03:26 PM
Shylor's Avatar
Shylor
I checked the NAPA online site and there is no match for that part number.
Old Oct 19, 2003 | 04:56 PM
slong's Avatar
slong
I called the local Napa over here, and 710-1028 is a good number. The kit is $96.59 but that's retail. It may not be available on-line.
[Modified by slong, 8:22 PM 10/19/2003]
Old Oct 19, 2003 | 06:46 PM
Painrace's Avatar
Painrace
Believe me guys, if you have a puncture it is well worth it. I keep it in my Z06 all the time. I am not sure how well it would work in freezing temperatures.
Old Oct 19, 2003 | 07:12 PM
slong's Avatar
slong
I'm in. Where my kid works they plug tires all the time, $15.00 a shot, no receipt. That's how they buy lunch. LOL
[Modified by slong, 8:23 PM 10/19/2003]
Old Oct 20, 2003 | 12:21 AM
Dug02Z0679L82's Avatar
Dug02Z0679L82
Default Re: Z06 tire pump kit (slong)
Pep Boys also sells a pump and fix-a-flat bottle kit. I saw one today, but didn't stop to get the price. I'm sure it is way less that GM or NAPA at $96. I don't think you'll feel the extra weight of the kit, but I would also recommend that you get a tire plug kit and try it first. So far I've been lucky and not used either.
To Z06 tire pump kit
