[Z06] only 323 rwhp!!!!
Old Oct 27, 2003 | 10:39 AM
427CPE's Avatar
427CPE
Default Re: only 323 rwhp!!!! (dvandentop)
When it was on my car the Vararam caused a severe, uncorrected lean condition and a loss of power. The reason was corrupted airflow through the mass air flow meter. Your PCM can not correct this situation. You must tune the car via pcm to correct this.
Also, at 1400ft, expect at least a 8% loss in hp at STP. Figure 50% loss of 02 at 18,000ft.
[Modified by 427CPE, 7:54 AM 10/27/2003]
Old Oct 27, 2003 | 10:42 AM
dvandentop's Avatar
dvandentop
Default Re: only 323 rwhp!!!! (rbartick)
it was 37 outside so i am assuming maybe 40 something since the shop door was open
Old Oct 27, 2003 | 10:54 AM
RussBt's Avatar
RussBt
From: Admit Nothing, Deny Everything, Make Counter Accusations.
Dyno numbers corrected to SAE J1349 alter the data to make it seem as if it was taken when the atmospheric pressure was 29.23 in/hg., the temperature 77 degrees F and the humidity zero.
Your ambient was way below 77 degrees F. Chances are good that your power displayed in SAE would have been lower than the uncorrected power value.
Old Oct 27, 2003 | 10:56 AM
dvandentop's Avatar
dvandentop
Default Re: only 323 rwhp!!!! (427CPE)
LOOK AT A/F CHARTS ABOOVE IN THE LINKS
[Modified by dvandentop, 9:57 AM 10/27/2003]
Old Oct 27, 2003 | 12:05 PM
427CPE's Avatar
427CPE
Ok, see what ya mean.
Old Oct 27, 2003 | 08:38 PM
WisconsinVETTE's Avatar
WisconsinVETTE
Senior Member
Cruise-In V Veteran
:confused:
Old Oct 28, 2003 | 12:46 AM
427CPE's Avatar
427CPE
Default Re: only 323 rwhp!!!! (WisconsinVETTE)
WisconsinVETTE,
->meaning his a/f don't look so bad. 12.6 is a bit rich for my taste at WOT, but not enough to kill off tons of power.
Old Oct 28, 2003 | 01:03 AM
427CPE's Avatar
427CPE
Check out this link. It will help you calculate hp changes due to weather conditions.
http://wahiduddin.net/calc/calc_hp_dp.htm
Old Nov 2, 2003 | 12:30 PM
z06 stocker's Avatar
z06 stocker
I am unsure why this is suprising anyone. A stock Z06 is running about 385 at the crank (so they say - and I believe it). At the rule of thumb number for transmission losses and the such (15% loss), the RWHP is 327. Close enough for me to say, o.k. To break 400 at the rear wheels, need about 470 at the crank. The Borla should add a little, but no more than a couple of RWHP without intake mods.
Old Nov 16, 2003 | 12:51 AM
dvandentop's Avatar
dvandentop
redynoed today and got 350 hp and 352 torque i am happy! :party:
Old Nov 18, 2003 | 07:23 PM
NorthernZ06's Avatar
NorthernZ06
did you change anything about the car? or just run the same setup again?
Old Nov 18, 2003 | 07:30 PM
dvandentop's Avatar
dvandentop
Default Re: only 323 rwhp!!!! (NorthernZ06)
exact same setup
made sure he dynoed in 4th gear
and filled up with 93
Old Nov 18, 2003 | 09:00 PM
  #33
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Most people agree that 385 hp is underrated.. most are 340 to 350. BTW my '01 w/ a vortex and stingers trapped at 114. The lower tension rings cause some excess blow-by but shouldn't hurt compression. Glad the dyno numbers are up. I'm may hit the dyno this Sunday. :cheers:
Old Nov 18, 2003 | 09:19 PM
  #34
TZL's Avatar
TZL
Dvandentop,
your sig is reversed and says you got 325 ft/lbs, i think you reversed the 2 and the 5
Old Nov 18, 2003 | 09:21 PM
  #35
dvandentop's Avatar
dvandentop
Default Re: only 323 rwhp!!!! (TZL)
oops
:D
Old Nov 18, 2003 | 09:23 PM
  #36
dvandentop's Avatar
dvandentop
nice santorin s4 i got a 2000 blue one :)
saw u on audi world before hopefiully you dont ahve a problematic 2004 model :crazy:
Old Nov 19, 2003 | 06:29 PM
  #37
CJS's Avatar
CJS
So how does the car feel SOTP now and before. If there was a real differece in that much rwhp then you would feel the difference. If it was just a "bad" dyno run then the car would have felt the same to you.
Old Nov 19, 2003 | 06:30 PM
  #38
dvandentop's Avatar
dvandentop
Default Re: only 323 rwhp!!!! (CJS)
felt the same to me!
Old Nov 19, 2003 | 07:03 PM
  #39
dubya's Avatar
dubya
St. Jude Contributor
RB, you blow my mind. :confused: Man you know alot about Dynos :cheers:
