[Z06] only 323 rwhp!!!!
Old Oct 25, 2003 | 09:26 PM
dvandentop's Avatar
dvandentop
Default only 323 rwhp!!!!
WTF i only got 323 rwhp and 323 torque on my 01 WTH!!
with the vararam and the borla that is creweed up on a dynojet as well :cry :cry
Old Oct 25, 2003 | 09:43 PM
Z06_Bob's Avatar
Z06_Bob
Default Re: only 323 rwhp!!!! (dvandentop)
You're probably running rich. That's what happened to me too when I added the Vararam. Get someone to do a tech2 and see what you're LTFT's and FAR is.
Bob
Old Oct 25, 2003 | 09:45 PM
dvandentop's Avatar
dvandentop
Default Re: only 323 rwhp!!!! (Z06_Bob)
fuel air sensor was running 12.3-12.6 all the way across the board
also the damn guy didnt CORRECT the numbers it is using STD horsepower any way to figure in correction???
Old Oct 25, 2003 | 09:51 PM
dvandentop's Avatar
dvandentop
here is the a/f sheet http://sio.midco.net/dvandentop/dyno/af1.jpg
http://sio.midco.net/dvandentop/dyno/af2.jpg
_________________
[Modified by dvandentop, 8:59 PM 10/25/2003]
Old Oct 25, 2003 | 10:17 PM
kh24's Avatar
kh24
Since the 01s have had problems with the piston rings maybe you should have a leak down test performed on the car.
Old Oct 25, 2003 | 10:18 PM
dvandentop's Avatar
dvandentop
Default Re: only 323 rwhp!!!! (kh24)
doesnt burn any oil
also here is a dyno
http://sio.midco.net/dvandentop/dyno/dyno.jpg
Old Oct 25, 2003 | 10:22 PM
kh24's Avatar
kh24
I would still get it done...STD correction usually yields higher numbers than SAE which we all use. Your power may be in the 31xs corrected to SAE standards. Get a compression test at least.
Old Oct 25, 2003 | 11:10 PM
dvandentop's Avatar
dvandentop
how much they usually charge for that???
Old Oct 25, 2003 | 11:15 PM
kumar75150's Avatar
kumar75150
Try and dyno one other place just for the hell of it.
Joe is right, SAE numbers are usually lower than STD/Ed Wright numbers.
You are under 320std according to that and there is something wrong.
Old Oct 25, 2003 | 11:19 PM
dvandentop's Avatar
dvandentop
Default Re: only 323 rwhp!!!! (kumar75150)
GREAT!
could bad gas through it off that much???
also did anyone look at the fuel/air ratio is that pretty whacked??
Old Oct 25, 2003 | 11:30 PM
dvandentop's Avatar
dvandentop
also several other cars 2 mustangs dynoed pretty poopiety as well
the one mustang with mods had exhaust and intake on a 99gt and he only dynoed 213 rwhp they come with 260 so that comes out to only 244 cracnk HP :confused: :confused:
could it be sumthing with operator error???
also dyno in 4th correct?
Old Oct 25, 2003 | 11:47 PM
kumar75150's Avatar
kumar75150
It could be the dyno or correction factor but you never know unless you dyno somewhere else. An AF ratio in the 12s will not hurt dyno numbers that much if at all. You are down 40rwhp. Thats a lot.
I almost want to believe that there is a Dynojet virus in the air. Almost every modded car I have witnessed dyno here in Dallas over the last couple weeks has been down on power by 15-25 hp. I am talking about cars at LPE, MMT, and Speedtek at least. Maybe our cars are just messed up.
I am going to get my springs checked to make sure I am not having any valve float and might even get a compression test done. I am down about 15hp from where I think I should be at.
Old Oct 26, 2003 | 12:40 AM
jw33's Avatar
jw33
Cruising
Are you at altitude????
Old Oct 26, 2003 | 12:43 AM
dvandentop's Avatar
dvandentop
Default Re: only 323 rwhp!!!! (jw33)
1423
Old Oct 26, 2003 | 02:36 AM
ledfoot's Avatar
ledfoot
I may be in left field here but have you given any thought to taking the car to the drag strip?
An 01 with your mods should easily pull a 12.8/112...
IMO, it's the only to know for sure what kind of power it's generating.
Good luck!
David In Indy
03Z-Ripper
12.5/113/1.9
Old Oct 26, 2003 | 08:09 AM
niphilli2's Avatar
niphilli2
Default Re: only 323 rwhp!!!! (ledfoot)
Dont put so much emphasis on the dyno, they very a bunch from place to place and day to day. Could be a lot of things.
Your A/F looks pretty good, maybe 5HP in leaning it out to 13.1 but you have a good safe A/F for the street.
You should try and get ahold of ATAP to run a few logs. Look at your Air Intake Temps and see what they read, then look at your timing tables. Also look for Knock Retard.
Old Oct 26, 2003 | 11:07 AM
dvandentop's Avatar
dvandentop
damn guys are closed already for the season
To only 323 rwhp!!!!
Old Oct 26, 2003 | 04:14 PM
dvandentop's Avatar
dvandentop
well i guess so guys video taped the runs of their stangs did the sticks in 3rd gear : so that is why they are so screwed but the auto car had fantastic #'s
[Modified by dvandentop, 9:22 PM 10/26/2003]
Old Oct 27, 2003 | 09:59 AM
dvandentop's Avatar
dvandentop
ttt should redyno then obviously right?
Old Oct 27, 2003 | 10:27 AM
RussBt's Avatar
RussBt
From: Admit Nothing, Deny Everything, Make Counter Accusations.
SAE corrected numbers are corrected to a specific set of weather conditions. If you dyno in better weather than the SAE specific set of weather conditions then your uncorrected numbers will be higher than SAE.
When you did your run what was the ambient temp in the shop? If the shop air was fairly cold (60 degrees or less) and the BARO was fairly high then SAE correction is not going to add siginicant power.
