[Z06] *** Opinions Please ***
Old Nov 15, 2003 | 10:22 AM
RiceEatingZR1's Avatar
RiceEatingZR1
Default *** Opinions Please ***
My friend decided to get a cam and headers for his Z06. How much power can he expect with this set up? How about drivability? How much difference in power and torque would there between the off road X-pipe and the one with the cats? (He has not decided yet on which to get) Please give some opinions or any suggestion you might have.
Here is what he plans on getting:
- Stock Heads
- Stock Modified Air Box W/ K&N
- 224/224 .581/. 581 114 LSA Camshaft
- Comp 918 Springs
- 7.400Â’ Chrome Moly Pushrods
- Dyno Tune
- LG Pro Long tube Headers W/ no cats -OR- with out
- Taylor 409 race wire 10.4mm
- NGK copper spark plugs
- 160^ stat
- ASP Underdrive crank pully
[Modified by RiceEatingZR1, 9:33 AM 11/15/2003]
Old Nov 15, 2003 | 12:02 PM
ZO6Les's Avatar
ZO6Les
Default Re: *** Opinions Please *** (RiceEatingZR1)
That is a fairly mild cam and with the 114 LS should be very streetable. Expect 10-15 RWHP from the headers, another 10-15 from the cam, 5 from the pulley. He should consider porting the heads and get a CAI.
Other opinions will vary. He might do a bit better, but with a stock airbox and heads the engine is not operating at peak efficiency with this setup, IMHO.
Les :cheers:
Old Nov 15, 2003 | 08:58 PM
RiceEatingZR1
Default Re: *** Opinions Please *** (ZO6Les)
Anybody else with some input?
Old Nov 17, 2003 | 12:00 PM
RiceEatingZR1
TTT
Old Nov 18, 2003 | 10:34 AM
RiceEatingZR1
Does anyone have a similar setup? How is the Drivability? :cheers:
Old Nov 19, 2003 | 04:12 PM
RiceEatingZR1
:confused: I take it no one has a setup like this? 150 views and no replies :cry well thanks anyway.. :leaving:
Old Nov 19, 2003 | 05:00 PM
User 81424's Avatar
User 81424
Take a look at Cartek they are making 417rwhp with ported heads and there "H" cam, if I was pulling the heads off I'd get a port job, some CAI, and an LS1 edit and he should be happy with rwhp.
Old Nov 19, 2003 | 06:11 PM
RiceEatingZR1
Default Re: *** Opinions Please *** (CPT Z06)
CPT Z06 thanks for your reply. :thumbs: those numbers look good, do you happen to know how the Drivability is?
Old Nov 19, 2003 | 06:18 PM
CJS's Avatar
CJS
I guess 415 to 425 rwhp. The cam will be very noticable compared to stock, but not brutal lumpy, idle may have to go up to 900rpms or so. Drivability will be like stock except in parking lot, traffic jams, crawling along and clutching situations. Then it will be just a little more balky and cranky than a stock car. If you don't mind the cams effect in the 800 to 1300 rpm range, then the car will be just a blast to drive.
[Modified by CJS, 6:20 PM 11/19/2003]
Old Nov 19, 2003 | 07:25 PM
1 Nasty Z's Avatar
1 Nasty Z
Default Re: *** Opinions Please *** (CJS)
:iagree: A lot more fun to drive would be an understatement. :auto:
Old Nov 19, 2003 | 07:40 PM
RiceEatingZR1
Default Re: *** Opinions Please *** (1 Nasty Z)
:hurray: cool thanks againg guys for the quick replies.. :thumbs:
Old Nov 19, 2003 | 08:29 PM
case2307's Avatar
case2307
I have almost the same setup. I have the same cam only with a 112...blackwing...LT's W/high flow cats...no pully. The car idles close to stock @ 900 except when it's hot out. Then it cams a little. I made 406/391. The pully goes on this weekend so I'll pick up a little more. :cheers:
To *** Opinions Please ***
