[Z06] Charge System Fault??????????
Old Dec 12, 2003 | 08:20 AM
theblackvette's Avatar
theblackvette
Default Charge System Fault??????????
I have seen this message come up a couple of times on the display indicator. Nothing seems to be wrong with the car at all. Should I be concerned? It only happened maybe twice. I usually look at the display when I turn on the car, force of habit! Thanks!
Old Dec 12, 2003 | 09:01 AM
theblackvette
Default Re: Charge System Fault?????????? (theblackvette)
This message is of concern to me. Although I only have seen it twice it can't be a good thing. It only happened on start up! I am really puzzled to what this means.
Old Dec 12, 2003 | 09:03 AM
Z06Joe@AutoBuffs's Avatar
0Z06Joe@AutoBuffs
Former Vendor
St. Jude Donor '08-'09-'10
I have only had the problem happen twice myself, and it was after the car had sat for a few weeks then I started it up. I have not had it happen since, and my battery volts are normal. How ever I am upgrading to a Red Top Optima, and I am curious to see if the car sits for the same period of time, if it will give the same message with the new battery.
Old Dec 12, 2003 | 09:05 AM
theblackvette
Default Re: Charge System Fault?????????? (Z06Joe)
Thanks for your message. So this message deals with the BATTERY? I guess as long as the car starts up then there is nothing to worry about? Right?
Old Dec 12, 2003 | 09:07 AM
0Z06Joe@AutoBuffs
Former Vendor
You are right, at least that is what I believe. But if the car hesitates on you and you get that message still I would take it and have the battery and alternator checked.
Old Dec 12, 2003 | 09:19 AM
theblackvette
Just got off the phone with the dealer! They told me to bring it in. They told me about a solonoid that some might be defective. They said it is an unservicable part and would need replacement. It is under warranty and will cost no $$$$ to replace.
Old Dec 12, 2003 | 09:21 AM
0Z06Joe@AutoBuffs
Former Vendor
What dealer did u buy your car from???
Old Dec 12, 2003 | 09:35 AM
theblackvette
Kelley Chevrolet=It supposedly the 2nd biggest new Corvette dealer in the US. They have a Horsepower shop there the is affiliated with the dealer.
RussBt's Avatar
RussBt
From: Admit Nothing, Deny Everything, Make Counter Accusations.
I sometimes get this when first starting if my car sits unused for a few weeks. I checked it out in the shop manual and if I remember correctly the code is set when the PCM detects lower than normal voltage for a specific amount of time. If you are getting this on a daily driver then I would check things out.
Old Dec 12, 2003 | 09:36 AM
0Z06Joe@AutoBuffs
Former Vendor
Is that Win Kelley Chevrolet?
Old Dec 12, 2003 | 09:38 AM
theblackvette
Default Re: Charge System Fault?????????? (rbartick)
Quote:"If you are getting this on a daily driver then I would check things out."
This is exactly what I am doing! I am going later today and they will check it out. I also inquired about mods. He was telling me about adjusting some "Throttle" thing. Do you know what this is all about? He said I would notice a big difference in performance!
[Modified by theblackvette, 2:38 PM 12/12/2003]
Old Dec 12, 2003 | 10:07 AM
RussBt's Avatar
RussBt
Sounds like :bs
Old Dec 12, 2003 | 04:54 PM
theblackvette
The fault appears to have been a loose wire. It was tightned so we will see what happens.
Old Dec 14, 2003 | 08:40 AM
theblackvette
I am happy to report that I have not seen this message show up on start-up since the cable was tightened!!!!!
:party:
Old Dec 14, 2003 | 10:36 AM
Michael Joslyn's Avatar
Michael Joslyn
I am sure I speak for many when I ask: Could you be more specific as to what, where, and how to repair this cable?
I get this fault from time to time, once it even threw 20 some codes! I had also heard there was a diode in the alt. that could cause a drain.
Thanks, Mike
Old Dec 14, 2003 | 12:47 PM
Tracy's Avatar
Tracy
Default Re: Charge System Fault?????????? (Michael Joslyn)
I also get this same brief message. It's totally random, and my car is a daily driver. It does not set a code on the DIC, so I figure it's just a very transient condition that corrects itself once the engine fires.
But I would like to know more about this loose cable, too.
Old Dec 14, 2003 | 03:34 PM
theblackvette
I will get a more specific answer this week from the dealer that tightened the cable.
I don't know much about the engine and how it works I just know how to drive the car.
However, any of you engine experts may be able to figure this out. First the dealer tested the battery. When that revealed nothing he put the vehicle up on the lift. I saw him tighten some cable from under the car towards the front of the car. He said he was able to "turn it one and a half more times" to tighten the cable. As for exactly what this cable was, I will have to find out, but you experts may already know what this is.
To Charge System Fault??????????
Old Dec 14, 2003 | 05:35 PM
Michael Joslyn
I would assume it was a ground. I should get out the service manual and see how many I can "see" and tighten up.
Keep us posted.
Old Dec 14, 2003 | 05:46 PM
Zero00's Avatar
Zero00
I got my 'charge system fault' message last week. No noticeable problems, no changes to start up, idle, etc. The only other message that I received was 'have a wild ride'......OK, I'm just kidding on the last one. :)
Old Dec 14, 2003 | 05:49 PM
theblackvette
Default Re: Charge System Fault?????????? (Zero00)
The dealer told me that if the DIC is reading charge system fault, there IS indeed a fault in the system at that given time. The voltage may be enough to start the car, but he said it was important to check out the car and make a note of it now!
Since the tightened cable-i have not seen any of these messages! I think there is a screw loose in many Z06's that are getting these messages!
