[Z06] Under Drive Pulleys
Old Dec 18, 2003 | 09:10 PM
Atl.Vette's Avatar
Atl.Vette
Default Under Drive Pulleys
Any Z owners out there that have underdrive pulleys?
I'm thinking about adding this to my list of mod's.
I worry about the stop and go traffic in the summer, and if the slower water pump might cause an over heating problem.
Any body have any daily driver problems?
_________________
'03 Black on Black Z06 :auto:
Old Dec 18, 2003 | 09:31 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Default Re: Under Drive Pulleys (Atl.Vette)
:lurk: Word of advice I hear the labor is way too much for the gains you'll get (unless you do it yourself). You have to drop the entire steering rack and it'll give you 5-7 rwhp. Most do it when they get a cam put in. That's what I'll do.
Old Dec 19, 2003 | 07:44 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
Default Re: Under Drive Pulleys (Cobra4B)
:iagree: Way too much work if that is the only thing you are changing. There's no sense in doing it unless you are changing the cam or heads/cam. Three is more to be gained from headers and/or air box.
Old Dec 19, 2003 | 08:21 PM
slong's Avatar
slong
I would go with a Meziere Water pump if your going to R&R the pulley's. Heck, even if you don't.
Old Dec 19, 2003 | 08:52 PM
ZO6Les's Avatar
ZO6Les
Default Re: Under Drive Pulleys (Z06ufgrad2002)
:iagree: I did it when I had the H&C work done, 10% under pulley with an alternator pulley too.
Les :cheers:
Old Dec 19, 2003 | 08:58 PM
Vegasr's Avatar
Vegasr
Default Re: Under Drive Pulleys (ZO6Les)
I too got the underdrive pulley when they did the cam upgrade. Wouldn't of been worth it if they just did the pulley by itself due to labor.
To Under Drive Pulleys
