[Z06] Active Handliing Error message
Old Dec 26, 2003 | 07:37 PM
TEXHAWK0's Avatar
TEXHAWK0
Default Active Handliing Error message
Has anyone with a 2004 Z06 experienced false Active Handling Error Codes on the DIC?
When my Z06 sets overnight, especially in cold weather, the Service Active Handling System message appears on the Driver Information Center. When I press the RESET button, the message clears and does not reappear when I restart the car the rest of the day. The codes set in history are C1282 H and C1288 H, which are the steering position sensor and yaw rate sensor bias circuit.
The codes have only appeared once when the car was moving, and appear mainly just when the car has set for several hours over night in the garage. It almost seems like the problem may be temperature related. I have not taken it to the dealer for service yet since it does not keep me from driving the car, and the problem may not be reproduced without leaving it for several days.
Anyone have a similar experience, or have an idea of what could be causing the problem?
[Modified by TEXHAWK0, 12:43 AM 12/27/2003]
[Modified by TEXHAWK0, 4:29 PM 12/27/2003]
Old Dec 26, 2003 | 08:08 PM
dubya's Avatar
dubya
St. Jude Contributor
Default Re: Active Handliing Error message (TEXHAWK0)
:seeya Texhawk0,
Someone should be along shortly to help. I'd take it to the dealer for warranty.
