[Z06] Rear End Noise
Old Dec 30, 2003 | 11:03 PM
2ZOOMZOOM's Avatar
2ZOOMZOOM
4th Gear
Default Rear End Noise
:confused: Help out :nono: My 2002 ZO6 has 11621 miles. Lately I have heard this grinding type sound coming from the rear axle area. This noise only happens when turning in a tight circle at low speeds. I know this has to do with limited slip traction, ie one wheel turning faster then the other in a radius. Is this sound normal???? Has anyone out there experienced this?? My local Chevy Dealer says its normal. I find this hard to believe.
Old Dec 31, 2003 | 08:48 AM
dubya's Avatar
dubya
St. Jude Contributor
Default Re: Rear End Noise (2ZOOMZOOM)
Welcome :seeya
I've never heard that noise. :nonod: Doesn't sound normal to me.
Old Dec 31, 2003 | 09:09 AM
FlyinNOE's Avatar
FlyinNOE
Welcome to the Forum. I have always had a little noise from the Diff when I'm turning hard at slower speeds (like in a parking lot, or doing a U turn). I've put 12,000 miles on, since I noticed it, with no problems. Dealer said it was normal when I first heard it.
I changed fluid just to see if it would make any difference and it didn't.
Just my .02
Brian :flag
Old Dec 31, 2003 | 09:29 AM
ZO6Les's Avatar
ZO6Les
Doesn't sound normal, to be sure (and since it is still under warranty) have the dealer listen.
Les
Old Dec 31, 2003 | 09:33 AM
Z_OH_6's Avatar
Z_OH_6
Default Re: Rear End Noise (ZO6Les)
Les
:iagree: Let the dealer check it out before too many more miles are put on. WELCOME to the Forum!! :cheers:
Old Dec 31, 2003 | 10:15 AM
sliderhss's Avatar
sliderhss
It's NORMAL!
At least according to the Z06 VHS tape that I receieved when I bought my 03 Z06.
Mine was making the noise with less than 50 miles on it. I reviewed the tape and sure enough the tape described the exact sound and said that it was normal.
Ask your dealer for a tape.
[Modified by sliderhss, 10:16 AM 12/31/2003]
Old Dec 31, 2003 | 02:13 PM
rwd's Avatar
rwd
It may or may not be normal. If the dealer has heard the noise (not just your description of it), and you still have doubts, visit another dealer or two- preferably ones that sell a lot of vettes.
Old Dec 31, 2003 | 02:42 PM
2ZOOMZOOM's Avatar
2ZOOMZOOM
4th Gear
Thanks Everyone,
Happy New Year to All. I will take your advice and take it to another dealer that may have more experience with the ZO6. Thanks Again :yesnod:
ZOOMZOOM :party:
How do you download pictures to post messages ??
[Modified by 2ZOOMZOOM, 11:44 AM 12/31/2003]
[Modified by 2ZOOMZOOM, 11:49 AM 12/31/2003]
Old Dec 31, 2003 | 03:40 PM
slong's Avatar
slong
Les
The video did mention noise at take off when stopped but did not mention it during a tight turning circle. Les has the right idea, take it in for inspection.
:iagree: :cheers:
Old Jan 1, 2004 | 08:21 PM
theblackvette's Avatar
theblackvette
Default Re: Rear End Noise (slong)
Never heard any noises except my exhaust!
Old Jan 5, 2004 | 07:06 PM
wilpwrr's Avatar
wilpwrr
2nd Gear
I took mine in for an oil change and noticed diff fluid leaking... took it in for service and they told me it was normal due to "over fill"... and took some of the fluid out. I started to hear the griding noise a couple of days later. it got progressively worse. the grinding noise on sharp turns or u-turn (and it only makes the noise when the clutch is engaged).
took it in again. after 3 days, the dealer told me it was due to the fact that they had to change my diff fluid, it required a special lubricant but that they could not put it in b/c it is outlawed in CA... wat b/s... they filled w/ other lubricant and it did not help...
after taking the baby in for servicing two more times, they changed the diff all together and it's been 10K miles since and i don't hear the grinding noise.
if you've got warranty get the diff changed. :rant:
Old Jan 30, 2004 | 11:32 AM
2ZOOMZOOM's Avatar
2ZOOMZOOM
4th Gear
Default Re: Rear End Noise (wilpwrr)
Hi
I'm still dealing with my aching baby. I finally got through to GM and they offered to replace the differential. I was wondering what exactly they did your car? Where you happy with the dealership and where did you take it? I have the option to to choose the dealer location. I want to make sure that where ever I take it they have the most experience. I appreciate your advise. :auto:
Old Jan 30, 2004 | 11:49 AM
Z06Berlin's Avatar
Z06Berlin
I had the same problem except my left rear wheel locked up, ended up replacing the differental.
To Rear End Noise
