[Z06] When to do the first Oil Change???
Old Jan 2, 2004 | 05:15 PM
Gonzo's Avatar
Gonzo
Default When to do the first Oil Change???
When did you do your first oil change???? I was thinking 500 miles is that dumb :confused:
Old Jan 2, 2004 | 05:21 PM
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
Default Re: When to do the first Oil Change??? (Gonzo)
Do a search, you will find answers that range from 1 mile to 5000 miles for the first oil change. If it makes you feel better doing one at 500, do it. It's your money. :cheers:
Old Jan 2, 2004 | 05:30 PM
slong's Avatar
slong
It is money well spent. Who knows what is :lurk: in your motor.
Old Jan 2, 2004 | 06:57 PM
mikeo's Avatar
mikeo
There was a thread on this not too long ago. I think a lot of members suggested doing it at 1,500 miles. That's when I did mine.
Old Jan 2, 2004 | 07:16 PM
DanteBoca's Avatar
DanteBoca
I did mine after the 1000 mile breakin period. I wanted to flush out all the manufacture and breakin impurities. Just my personal choice.
Old Jan 2, 2004 | 07:30 PM
mqqn's Avatar
mqqn
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi Gonzo -
You probably do not have to change the oil at 500 miles.
I would, I did and I will do so again on my next Vette. I love to play with the Z, and I love to crawl under it and pull off the oil filter. :thumbs: :chevy :steering:
best regards -
mqqn
[Modified by mqqn, 6:32 PM 1/2/2004]
Old Jan 3, 2004 | 10:58 AM
Gonzo's Avatar
Gonzo
Default Re: When to do the first Oil Change??? (mqqn)
THanks Guys, I know its an old question but this is my first new car :D
Old Jan 3, 2004 | 11:25 AM
slong's Avatar
slong
Congrats! Take good care of it, and hopefully it will return the favor. I changed mine early also. All that assembly lube, dust, metal fragments, BZZZZZ there’s the break bell technician goes on a break - motor sitting wide open for who knows how long, how it gets assembled all comes into play.
:cheers:
Old Jan 3, 2004 | 11:31 AM
Z_OH_6's Avatar
Z_OH_6
Default Re: When to do the first Oil Change??? (slong)
Congrats! Take good care of it, and hopefully it will return the favor. I changed mine early also. All that assembly lube, dust, metal fragments, BZZZZZ thereÂ’s the break bell technician goes on a break - motor sitting wide open for who knows how long, how it gets assembled all comes into play.
:cheers:
You just have to agree with good common sense. :iagree: Congrats on the new car!
Old Jan 3, 2004 | 12:49 PM
texasredc8's Avatar
texasredc8
You will get a ton of answers...... that's for sure.
Changing your motor oil after break-in is old school, as these motors do not come from the factory with break-in oil. The LS1 and LS6 do not require this change. Will it hurt.... no. All of the metal shavings have already circulated in your oil and are now trapped by the oil filter. Heck, you could change your oil daily if you wanted. Its just with a good quality synthetic, you don't need to change your oil after break-in or every 3000 miles. This procedure dates back to the time of mineral oil usage in engines. I do see the logic in changing the oil to add the magnetic plug and a better oil filter, so this makes sense.
I'm on my 2nd C5. Both are changed at 5000 mile intervals (convenience and daily driving.) The DIC says 7000 miles for my Z. Neither has burned significant amounts of oil between changes and both have dynoed at normal levels. I am currently burning up the equal of 1qt in 20,000 miles.
You don't need to change the oil at any lower levels than what the DIC says, as long as you use synthetic oil that meets GM4718M specs. However, if you have extra $$ and enjoy working on your car....... go for it. You will not cause any damage from frequent oil changes.
Old Jan 3, 2004 | 03:00 PM
larrysb's Avatar
larrysb
Default Re: When to do the first Oil Change??? (TexasRedZ06)
Agree, I changed the first oil when the DIC hit about 28% oil life remaining. My car does not consume a drop of oil now either. It even looked "clean" when I changed it.
The right answer is: At LEAST as often as the DIC says.
As long as you do at as soon as the computer or manual says so, or more often, you're golden. Keep records and use the good stuff.
Old Jan 3, 2004 | 03:11 PM
CRWDDYZ's Avatar
CRWDDYZ
[QUOTEI do see the logic in changing the oil to add the magnetic plug and a better oil filter, so this makes sense.
[/QUOTE]
This begs a answer I have been wondering ? What is the best oil filter ? :confused:
Old Jan 3, 2004 | 06:35 PM
slong's Avatar
slong
Default Re: When to do the first Oil Change??? (C54EVER)
This may help some in deciding what oil filter to buy. http://www.minimopar.net/oilfilterstudy.html
:cheers:
Old Jan 4, 2004 | 03:55 AM
texasredc8's Avatar
texasredc8
:cheers:
I've read that review many times........ gives me a headache. :lol:
Seems the Mobil 1 or Pur1 is the best based upon what he tested.
Unfortunately, he never got around to the ACDelco Ultraguard Gold. I'm going on a limb by extrapolating that the Ultraguard has all the advantages of the best made Champion/Bosch/Deutsch filter with a synthetic media instead of paper media. One day, maybe I'll cut up one of my $8 Ultraguard Gold's and compare to the other filters on this website.
One thing for sure.......... stay away from the Fram made filters!!
Old Jan 4, 2004 | 10:47 AM
neile's Avatar
neile
CI 3-5-8 Veteran
Everyone has an opinion: mine is do it when convenient before say 1500 miles.
Old Jan 4, 2004 | 10:59 AM
Geneus's Avatar
Geneus
:iagree: What he said, most definately! Although, I am not sure about the magnetic plug thing. I thought are engines are a great deal of aluminum, a non-magnetic metal. :confused:
[Modified by Geneus, 4:03 PM 1/4/2004]
Old Jan 4, 2004 | 11:26 AM
ZO6Les's Avatar
ZO6Les
I did my first one at 500 miles, second at 2K and thereafter at 3K plus or minus depending on track time. I also recommend upgrading the filter to an Amsoil, UPF, K&N or Mibil 1.
No doubt this is overkill, but it is what I prefer and recommend. Other opinions will vary :)
Les
[Modified by ZO6Les, 10:28 AM 1/4/2004]
To When to do the first Oil Change???
Old Jan 4, 2004 | 01:01 PM
Gonzo's Avatar
Gonzo
Default Re: When to do the first Oil Change??? (ZO6Les)
On the oil filter front, K&N or Mobil One ??????I see both in Mid America
I have always use mibil One 5w30 with a mobil one filter, but the K&N has a special drainback valve to prevent dry start. Which is better????
And Is mobil one still the best choice for oil???
Sorry each question gets a little more in depth :crazy:
Old Jan 4, 2004 | 01:03 PM
Gonzo's Avatar
Gonzo
One more does the Zo6 use the same filter as the coupe . in other words does the LS6 use the Same filter as the LS1
Old Jan 4, 2004 | 02:14 PM
ZO6Les's Avatar
ZO6Les
The Z06 uses the UPF 44/46, don't know about the LS1. As far as oil goes lots of opinions there as well. For street use, in Georgia, I recommend Mobil 10W30 year round. Some who track their cars a lot run a 20W40 synthetic during the summer months - IMO that is fine too. As far as the K&N advantage in design for flow-back it is my understanding that this only applies to side mount filters - but I am not an expert on that either :)
Les :cheers:
