[Z06] Radiator Hose Question
Old Jan 29, 2004 | 09:46 AM
steve1173's Avatar
steve1173
Default Radiator Hose Question
Just recently got my 04 Z06 & looking things over. I noticed a small diameter rubber hose wrapped in black braid coming from the top passenger side of the radiator going towards the motor & passing over the top large radiator hose & resting on it. Seems there might be a clip missing on the radiator housing to hold this small hose up & not rest on the large one. Is yours the same way or is clipped to the housing?? Thanks.
Old Jan 30, 2004 | 02:29 PM
steve1173's Avatar
steve1173
Default Re: Radiator Hose Question (steve1173)
Reason I asked this even though it might seem minor is my friend was looking at my new Z06 engine & commented that he did not think the hose I mentioned should be resting on the upper radiator hose as it might create a soft spot on it from holding in nthe heat resting on it. That is why I asked if there should be a clip to hold it up on the plastic radiator housing as there is also a hole in the plastic that might be for a clip.
