[Z06] High Performance Computer Chip for the Z06???
Old Feb 2, 2004 | 08:54 PM
lager99's Avatar
lager99
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Default Re: High Performance Computer Chip for the Z06??? (Sandra Bigwoode)
You won't get 27hp but you will definately get 10-15 & it's quite noticable. :yesnod:
Old Feb 3, 2004 | 01:38 AM
stano's Avatar
stano
and there are people that think their new air intake or tb or corsa exhaust give them that much and more, let's see sae dyno numbers in a controlled test, ie, change only 1 thing at a time and retest...
gm had to do a lot of stuff to the heads on the 2001 z06 to boost the hp from 385 to 405, do you think they have not wrung out every last gain from the stock later z06's at 405 hp?
Just curious...why did you have your airbox ported If you think this stuff won't work??? Peace ;)
[Modified by stano, 12:39 AM 2/3/2004]
Old Feb 3, 2004 | 03:37 PM
ZEDohSIX's Avatar
ZEDohSIX
Default Re: High Performance Computer Chip for the Z06??? (Painrace)
Painrace: have you driven your car to 182 or is that a calculation? Curious because there are lots of other threads about what the top speed is/could be. If you have done this (driven at 182) then you have answered their questions.
Old Feb 3, 2004 | 09:11 PM
Painrace's Avatar
Painrace
Default Re: High Performance Computer Chip for the Z06??? (ZEDohSIX)
I have driven the car several times to 182-183 range. It will get there with the extra RPMs. The motor wont pull to 7,100 it just can't make it past 6,900 plus a little. My car was not very good past 155 MPH and I had it aligned with a GM Master Tech and he rode with me on one 180+ round. The car was very steady after the alignment.
I forgot. I am a retired racer. It would take me a long time to calculate top speed. It is more fun and much more exact to just do it. I assume speedometer is close???
[Modified by Painrace, 9:13 PM 2/3/2004]
Old Feb 4, 2004 | 05:13 AM
ZEDohSIX's Avatar
ZEDohSIX
I've cross checked my speedo (standard tires) against a GPS and it was spot on (less than 1kmph = 0.5mph error).
Well then I guess you answered the posts about whether a Z06 could keep up with a ZR1 and wether it is just a matter of gearing and not HP.
Old Feb 4, 2004 | 04:47 PM
dfwroadkill's Avatar
dfwroadkill
St. Jude Donor '07-'09
Quote:
it will be nearly impossible to find much more performance in a stock z06 by re-programming the pcm, they are really well tuned straight out of bowling green, ky...
________________________________________ _______________________
:eek: :rolleyes: :rolleyes: :eek: :leaving:
Old Feb 4, 2004 | 09:57 PM
Sandra Bigwoode's Avatar
Sandra Bigwoode
Default Re: High Performance Computer Chip for the Z06??? (stano)
i did it myself just to see if it works.
apparently not, it is hard to tell.
