[Z06] Tire Valve Stem Caps
Old Feb 13, 2004 | 05:03 PM
steve1173's Avatar
steve1173
Default Tire Valve Stem Caps
Will putting a set of metal tire valve stem caps on the tires effect the tire balance since they are heavier then the plastic ones???
Old Feb 13, 2004 | 07:25 PM
pk2401's Avatar
pk2401
St. Jude Contributor
Default Re: Tire Valve Stem Caps (steve1173)
I don't think 1/10 of an ounce would make much of a difference. I have chromed caps and the car is still aligned very well. You never know though. I had my tires balanced with the stem caps already on. Good question.
Old Feb 13, 2004 | 08:20 PM
OCS_1's Avatar
OCS_1
Default Re: Tire Valve Stem Caps (pk2401)
I've gone around and around on this one with the guys that do my balancing. My 03 Escalade has the roughest ride since I put the 20's on it and the balance just doesn't seem to last, so I got in to a discussion with these guys (it's what they do for a living) and they went so far as to say that since today's dynamic spin balancers measure (supposedly) down to an ounce, that picking up a rock in your treads and or having one in the treads at the time of balance could effect the overall vibration more so than a perfectly new tire on a perfectly clean rim. So, now when they remove the tires, after they check the thread for damage and uneven wear, I take a minute and clean the inside of the rims before they spin balance.....is it all worth it? Who knows?...but we do what we gotta do to sleep at night.
:_dupe:
To Tire Valve Stem Caps
