[Z06] Zaino Tip
Old Feb 24, 2004 | 06:06 PM
xlr8nflorida's Avatar
xlr8nflorida
Default Zaino Tip
If you wear a Latex Glove, the clay bar sticks to your hand, and it is not as likely to slip onto the dirty floor.
Just don't been seen in public or people might start calling you wacko jacko
Old Feb 25, 2004 | 02:02 PM
DocSandy's Avatar
DocSandy
From: When I say who is the mastah you gotsta say Shonuf
Default Re: Zaino Tip (xlr8nflorida)
I thank you for both tips.
Old Feb 25, 2004 | 02:54 PM
Corvette SSX's Avatar
Corvette SSX
St. Jude Donor '08
Default Re: Zaino Tip (DocSandy)
:iagree: :lolg:
Old Feb 25, 2004 | 10:49 PM
LT's Avatar
LT
I have mentioned this before. The best applicator that I have found for Z1 and Z2 can be purchased at WalMart. They sell two 3 inch round sponge terricloth applicators in a package. They allow a very thin application and work great. :thumbs:
Old Feb 25, 2004 | 11:10 PM
xlr8nflorida
Default Re: Zaino Tip (LT)
I will look into this, sometimes at walmart you have to be careful some of their so called "cotton" stuff as alot of filler and can scratch the paint.
I always light it on fire to see what happens. If you blow out the fire and the burn mark is soft -- you are good to go cotton.... if you get a hard knobby feeling thing then the towel is junk -- better to shine your shoes with. :cheers:
Old Feb 25, 2004 | 11:14 PM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
:thumbs:
Old Feb 26, 2004 | 01:41 AM
02 batmobile's Avatar
02 batmobile
I've seen mention of using a clay bar in previous threads. I have to admit that I know nothing about what it does. What is the purpose and how long does it take start to finish? It must make a BIG difference in the shine? :confused: :confused: :confused:
Old Feb 26, 2004 | 11:24 AM
av8or3's Avatar
av8or3
Default Re: Zaino Tip (02 batmobile)
A clay bar is most often used to remove dirt (or things like rail dust,overspray) from the finish of a car before you wax it. Heck of a cleaner.
Tecnique varies,but the fastest way I've found to use it is to get a bucket of soapy water to repeatedly dunk it in,hold it in your hand while you rub it over the surface of your car to lift off the contaminates. I use a circular motion and I use plenty of soapy water as a lubricant. You use your other hand to verify it's clean (feels VERY smooth). From time to time I fold the bar up in on
itself to expose a fresh surface for use on the paint. (it will collect lots of dirt,
even on a "clean" car,so do this often) Takes about as long as it does to wash your car. (but you must wash and dry your car afterward)
If you ever clay bar a car with lots of overspray on it,you will not soon forget how well it works,it is amazing. I would never try to "polish" off
overspray ever again. The bar gets every bit of it and is painless by comparison. Why couldn't I think of stuff like this?? :banghead:
Old Feb 26, 2004 | 06:08 PM
xlr8nflorida
Default Re: Zaino Tip (av8or3)
You might want to reconsider doing straight lines, if you do get some minor scrathches, it will be less apparent then circular scratches just my 02 cents :cheers:
To Zaino Tip
