[Z06] Z06 engine durability
Old Mar 8, 2004 | 11:10 AM
ivan111's Avatar
ivan111
Default Z06 engine durability
I know a guy that bought a Z two years ago to used it exclusively at the track for circuit.....
After two years of intense running it at track he blew the engine, he just installed the new engine....
My question is if it is normal for an engine that is going to be used at the track to last just 2 years? :confused:
[Modified by ivan111, 4:10 PM 3/8/2004]
Old Mar 8, 2004 | 11:39 AM
Zoomin's Avatar
Zoomin
2018 C2 of Year Finalist
St. Jude Donor '12-'13-'14-'15, '19
Default Re: Z06 engine durability (ivan111)
You're supposed to add an extra quart for that kind of use. If the engine gets starved of oil, it won't last a day, much less two years. If people are seriously into racing, two years is probably average.
Old Mar 8, 2004 | 11:44 AM
QUIKAG's Avatar
QUIKAG
If he blew the engine, then he either overreved it or starved the engine of oil and spun a bearing, etc. If you keep track of the oil level, pressure, and temp, the engine should last a long time.
Old Mar 8, 2004 | 12:58 PM
ivan111's Avatar
ivan111
Default Re: Z06 engine durability (Zoomin)
Oh okay next time i see him i will ask him.......
But does an extra quart of oil will take some power from the engine since the crank is flooded with oil?
I read that one of the advantages of Dry Sump Lubrication systems is that since the Crank is not flooded with oil the engine can generate more power because it has less friction from the excessive oils in comparison with Wet Sump Lubrication........
:rolleyes:
[Modified by ivan111, 5:59 PM 3/8/2004]
Old Mar 8, 2004 | 01:47 PM
dubya's Avatar
dubya
St. Jude Contributor
:rolleyes:
That holds true but not at the high RPM's needed for racing. :cheers:
Old Mar 8, 2004 | 02:02 PM
Zoomin's Avatar
Zoomin
Theoretically, if you're on a track most of the oil is pressed up against the sides of the oil pan. The extra quart ensures the oil pickup is covered in high g situations.
Old Mar 8, 2004 | 03:33 PM
ivan111's Avatar
ivan111
You are right since the Z accelerates, brakes and corners so hard you are under constant high g forces that moves the oil from side to side continuously....
So if there is power loss from the excessive oil is in low g situations.....
So these means that the next Z definetly needs to have Dry Sump
Lubrication.... :yesnod:
Old Mar 8, 2004 | 03:46 PM
ivan111's Avatar
ivan111
I was reading that the C6 has a wingless oil pan that provides better lubrication under high g forces........
Can somebody elaborate on what is this? :rolleyes:
Old Mar 8, 2004 | 04:43 PM
Jim 47's Avatar
Jim 47
Adding another quart of oil for racing does not flood the crank with oil. If you've seen the inside of the LS6 or the LS1 engine you will see that it has a windage tray between the crank and the liquid oil in the oil pan. This prohibits the oil from being aereated. The extra quart of oil helps to assure that the oil pump pickup will stay covered with oil during high G movements of the car. Keeping adequate oil pressure to all contact surfaces in the engine is paramount to long engine life.
I've been running an LS1 engine on the track for 4 years, and have had NO lubrication problems. The engine runs as strong today as it did 4 years ago. The chances are that your friend sucked some air into the oil system, and air doesn't lubricate very well.
Jim
Old Mar 8, 2004 | 05:03 PM
ivan111's Avatar
ivan111
Default Re: Z06 engine durability (Jim 47)
The LS2’s new oil pan was developed to ensure oil delivery commensurate with Corvette’s high-performance capability. Extensive track testing has shown the new design to provide better oil control under the extreme demands of high-rpm/high g-force driving maneuvers. The elimination of the previous “gull wing” oil pan design also reduces the engine’s oil capacity from 6.5 quarts to 5.5 quarts with a dry filter.
Intresting but they don't explain how does it improves the lubrication to the engine...... :confused:
Old Mar 8, 2004 | 05:10 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Well hopefully it'll bolt right up to ls1/ls6 mills.
Old Mar 8, 2004 | 05:52 PM
av8or3's Avatar
av8or3
I believe that if the car was bought for racing and thats what it's been doing for the last two years,the guy probably was surprised it lasted as long as it did. Shucks, he was ready to change the engine shortly after he bought it if
he's really serious about road racing. I think two years is definately a testament to the engine's reliability. Don't you? :smash:
Old Mar 8, 2004 | 06:24 PM
Roadfrog's Avatar
Roadfrog
Default Re: Z06 engine durability (av8or3)
I would have to agree. Two years is amazing to me. How many other racing engines last this long? A good Nascar engine is torn down after "only" 500 miles.
Old Mar 8, 2004 | 08:50 PM
ivan111's Avatar
ivan111
Default Re: Z06 engine durability (Roadfrog)
He also told me that he already placed the order for a C6 Z06 to replace his car next year........ :hurray:
To Z06 engine durability
