[Z06] Rev Limiter
Old Mar 13, 2004 | 08:21 AM
Roadfrog's Avatar
Roadfrog
Default Rev Limiter
Hit the rev limiter last night in both first and second (was just doing what I had to do at the time, most understand this).
It seems on a ZO6 that hitting the limiter is a very "violent" reaction as in popping and stuttering in the engine before the gas kicks in again. Much more so than in other cars I've hit the limiter with: BMW's, Miata's, Crown Vic, Chevy Pickup, you name it.
Just wondered if too much of this hurts the engine? When I hit it, I get off the gas quick. Just seems like an unusually strong reaction from the engine when the limiter kicks in. The engine runs fine when the gas comes back on. Opinions sought. Thanks and have a neat day. :auto:
Old Mar 13, 2004 | 08:33 AM
Z_OH_6's Avatar
Z_OH_6
Default Re: Rev Limiter (Roadfrog)
The car is designed to limit the revs that way to prevent real damage from occuring but too much of it for too long a time is definitely not a good thing. Just be sure to shift at lower points. :cheers:
Old Mar 13, 2004 | 09:02 AM
tT-REXXX's Avatar
tT-REXXX
Get your self a hypertec download you can change the redline.I think they work on zo6's Sombody here probably knows.I don't own a zo6,but it works on my auto. :jester
Old Mar 13, 2004 | 10:18 AM
Thud's Avatar
Thud
occasionally bouncing off the rev limiter won't hurt anything. First gear goes by so quick that it can be hard to avoid sometimes.
Just shift sooner.
Never really thought mine was "violent" though. :confused:
[Modified by Thud, 10:19 AM 3/13/2004]
Old Mar 13, 2004 | 12:43 PM
QUIKAG's Avatar
QUIKAG
Just get a reprogram and raise your rev limiter to 8500rpm or so. You won't have to worry about that pesky rev limiter anymore, though you rev it too higher, you're engine will blow up into a bunch of little expensive pieces. :D
Old Mar 13, 2004 | 02:06 PM
User 81424's Avatar
User 81424
I've always thought the rev limiter was fairly gentle, I mean you know when you hit it, but no big deal.
Old Mar 13, 2004 | 02:21 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
Default Re: Rev Limiter (CPT Z06)
:iagree: Not a big deal. It does what it is supposed to do and that is keep you from winding up with a bunch of pieces of scrap metal. :auto:
Old Mar 13, 2004 | 06:36 PM
bud miller's Avatar
bud miller
i hit it often-in 1st no big deal-the thing that makes it "violent" your just not used to it-and its more your reaction-everything just sorta "quits"!
man -just shift it and keep going,i smoked a nissan 350 z the other weekend-i hit the limiter in 1st because he was trying to "pinch me off on a two lane going into one, we had left from an intersection and as soon as i hit 2nd he was about a car length behind and after that he didn't want any more.. so he dropped back and stayed his distance- :mad :D :steering:
Old Mar 13, 2004 | 09:16 PM
C5 Hardtop's Avatar
C5 Hardtop
I've got to get a shift light. I can't stay off that limiter :D The tach is too darn slow ;)
Joel :chevy
[Modified by C5 Hardtop, 6:17 PM 3/13/2004]
Old Mar 14, 2004 | 02:06 PM
MikeNMaxZO6's Avatar
MikeNMaxZO6
Default Re: Rev Limiter (C5 Hardtop)
:iagree:
Old Mar 14, 2004 | 02:21 PM
lager99's Avatar
lager99
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Shouldn't really be viloent unless you fnish the 1/4 mile in first gear. That might get a bit uncomfortable. :crazy: Assuming you only missed the shift by a couple hundred RPM get should just get the average engine fart the rest of us get. :cheers:
Old Mar 14, 2004 | 03:04 PM
theblackvette's Avatar
theblackvette
Default Re: Rev Limiter (Thud)
I agree with Thud!
I usually agree with the Thudmeister!!!!!!
:cheers:
Old Mar 14, 2004 | 09:24 PM
Roadfrog's Avatar
Roadfrog
Default Re: Rev Limiter (theblackvette)
No, I'm not used to it in the sixer. It is different than other's I've hit.
Heck, all I was doing was trying to do the speed limit in first gear on the Interstate since I was too lazy to shift. I never exceed the speed limit unless I have to. :lolg:
Thanks dudes. :cheers:
To Rev Limiter
