[Z06] How often do you use 6th gear?
Mar 26, 2004 | 08:12 PM
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Re: How often do you use 6th gear? (mforman42)
I use it on any highway. :chevy
Mar 28, 2004 | 05:33 PM
I use it daily!
Mar 28, 2004 | 08:52 PM
Re: How often do you use 6th gear? (Cabinetman)
6th is rare.
I plead the 5th.
Bill. :blueangel:
Mar 28, 2004 | 09:42 PM
I only use 6th just to make sure its still there. :smiliedrool:
Mar 29, 2004 | 04:35 PM
Re: How often do you use 6th gear? (SQEZN BI)
Quote:
After reading how many people use 6th gear at such low rpm's, its know wonder the rings had problems .
Further to what Roadfrog said, ring flutter was the cause, and it occurs during high rpm, light load. Check the TSB.
Mar 29, 2004 | 07:00 PM
Re: How often do you use 6th gear? (rwd)
Rarely, only to quiet the ride.
Apr 28, 2004 | 04:01 PM
Re: How often do you use 6th gear? (robz)
I use it as "Cruzing gear".(freway mostly)
I just make sure I stay above 2000 RPM (but that's just me)
:steering:
[IMG][/IMG]
Apr 28, 2004 | 04:46 PM
When just driving around I keep the RPMs above 1,000. 5th gear at 1,000 = 35 MPH. 6th gear at 1,000 = 40 MPH. I don't try to accelerate with the engine at 1,000 PRMs. Lower gears are for accelerating. I have had several Z06's with no problems.
Apr 28, 2004 | 05:20 PM
Re: How often do you use 6th gear? (Painrace)
I use it all the time - when I can remember I have it. Under light accleration I often go from 4-6.
:steering:
1000 ,
2002 ,
55 ,
6th ,
c4 ,
c5 ,
corvette ,
freeway ,
gear ,
highway ,
low ,
sixth ,
tuneup ,
work ,
z06
