[Z06] ? regarding diff fluid and trans fluid?
Old Mar 31, 2004 | 08:17 PM
RMilla17's Avatar
RMilla17
Default ? regarding diff fluid and trans fluid?
I drive hard/autox/roadcourse... I also have 4.11 gears installed.
Should I use Mobil1 75W-90
Also who makes tranny fluid for my car? Mobil 1 etc....
I dont think i want to use redline so who else makes the tranny fluid? thakns
Old Mar 31, 2004 | 08:47 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Default Re: ? regarding diff fluid and trans fluid? (RMilla17)
I use AMSOIL synthetic ATF and love it. Why no Redline :confused: it's great stuff.
Old Mar 31, 2004 | 10:24 PM
RMilla17's Avatar
RMilla17
Default Re: ? regarding diff fluid and trans fluid? (Cobra4B)
You can use ATF for a manual transmission?so i can use mobil ATF for my tranny then?
Old Mar 31, 2004 | 11:23 PM
Zen06's Avatar
Zen06
Use synthetic Dexron III in the gearbox. Use synthetic 75W-90 gear lube and add 4 oz of anti-slip additive--I personally add 2 bottles (8 oz.)
Old Mar 31, 2004 | 11:30 PM
pwrshhftd's Avatar
pwrshhftd
Default Re: ? regarding diff fluid and trans fluid? (Zen06)
My highly respected tech says to use reg atf fluid.
Supposedly without a trans cooler, temperatures stay lower with regular atf..
Old Apr 1, 2004 | 01:08 PM
Wah's Avatar
Wah
I use Amsoil Universal ATF (synthetic) for tranny and Amsoil Series 2000 75W-90 for diff. GM does specify ATF for the tranny. Mobil1 synthetic gear oil is good enough for the diff and most synthetic gear oil doesn't need limited slip additive and putting too much additive makes the lubricant too slippery for the LSD.
Redline products are also superior, I'm just cheap :)
[Modified by Wah, 6:09 PM 4/1/2004]
To ? regarding diff fluid and trans fluid?
