[Z06] Neutral Safety Switch
Old Apr 28, 2004 | 03:47 AM
Donovan 572's Avatar
Donovan 572
Default Neutral Safety Switch
Has anyone disabled their clutch safety switch? I wouldn't mind disabling mine if it's an easy mod on these cars.
I know on my old Corvettes depressing the clutch to start the motor ruins the crankshaft thrust bearing over time. The reason is because when you press on the clutch pedal you are pushing on the crankshaft which is in turn pressing on the crankshaft thrust bearing. When you do this to start the car in the morning all of that pressure is going on a thrust bearing with little or no oil on it, so over time it ruins the thrust bearing.
I'm not sure if the LS1 has this same problem but I would guess that it does. Can anyone shed a little more light on this subject? I've searched for past threads about disabling the neutral safety switch on this forum but didn't find anything relating to C5s.
[Modified by Donovan 572, 9:52 AM 4/28/2004]
Old Apr 28, 2004 | 08:32 AM
User 81424's Avatar
User 81424
Default Re: Neutral Safety Switch (Donovan 572)
There are some real high mileage C5s out there and I've never heard about premature wear. I would think the safety of the clutch starter switch far outweighs a little extra life of a cheap bearing that is going to wear out anyway.
Old Apr 28, 2004 | 10:52 AM
Donovan 572
Default Re: Neutral Safety Switch (CPT Z06)
While the crankshaft thrust bearing may seem like a cheap part, in most cases it requires removal and dissasembly of your motor to change it (not cheap). I've taken apart several big block Corvette motors that have had this bearing trashed because of the clutch safety switch. The safety switch is only there for idiots that don't have enough sense to put a manual trans car in neutral before starting it. Chances are that if a person doesn't have enough sense to put the car in neutral before starting it, that same person doesn't have enough sense to put it in neutral before letting the clutch out AFTER starting it. :lol: I've always disabled it on my past Corvettes and have never had a problem.
[Modified by Donovan 572, 10:10 AM 4/28/2004]
Old Apr 28, 2004 | 03:33 PM
pnielsen's Avatar
pnielsen
Yup. BTW, isn't this dummy option a US-only option?
I've never encountered it on cars in Europe where manual transmission is predominant, and still today I believe cars sold in Europe don't have this option. Not long ago I read about a guy in Sweden that had a brand new top-of-the-line BMW equipped with DVD, playstation, navigator; the whole nine yards. He parked it at the edge of a pier. Some of his friends who wanted to demonstrate something cranked it up (with the gears in first) and it went down the deep end... :D
An interesting side note is that Chevy recommends us to park with the gears in reverse. Generally, it seems like people in Europe learn that the recommended way is to park with gears in first. (Which BTW is what Ford manuals recommend).
Old Apr 28, 2004 | 07:44 PM
West Coast Chris's Avatar
West Coast Chris
Ducktape the plunger on the switch will allow you to start any time. :chevy
Old Apr 29, 2004 | 08:02 AM
TEXHAWK0's Avatar
TEXHAWK0
"I've always disabled it on my past Corvettes and have never had a problem."
What is the best way to disable the circuit besides mechanically forcing the switch to stay in the closed position?
Does it hurt anything for that circuit to stay activated all the time?
:confused:
Old Apr 29, 2004 | 12:50 PM
Donovan 572
Default Re: Neutral Safety Switch (TEXHAWK0)
:confused:
The wiring and computer of the new Corvettes is a new thing for me. But in the old Corvettes it was no big deal. I would just wire around the clutch switch (maybe with a jumper wire on the back of the plug), but I would try to make it where it could be put back stock easily. I don't like to permanently alter things on a desirable car if possible.
On the old Corvettes the clutch switch just completed the circuit from the starter switch (when you turn the key). When you crank the motor with the starter is the only time there was current flowing in that circuit. I would guess that's pretty much still the way it works.
To Neutral Safety Switch
