[Z06] Anyone ever do a 4 corner balance?
Old May 13, 2004 | 06:34 PM
Guest
Guest
Posts: n/a
Default Anyone ever do a 4 corner balance?
My Z06 has always had a little over steer on LH turns when hotlapping/DE events regardless of what tires I used.
Anyone ever do a 4 corner balance and notice any difference?
Thanks.
[Modified by Chalky'sC5, 9:40 PM 5/13/2004]
Old May 13, 2004 | 09:49 PM
Clay's Avatar
Clay
Default Re: Anyone ever do a 4 corner balance? (Chalky'sC5)
Yes, I run open track events and I have corner weighted my 98 Z51 coupe and I recently had my 04 Z06 corner weighted as well. At the same time I had the corner weights done I had my alignment set to the specs of my liking as well which are Fr= 1.5 neg camber, .04 toe out, 7.0caster, Rear= 1.2 neg camber, .06 toe in. I cannot objectively seperate the benefits from the corner weight because they were done at the same time but OMG!! do the two together make an unbelievable difference in the turns. I literally did this mod and nothing else and cut almost 3 full sec off my lap times at Putnam Park Indiana. Hope that helps.
Old May 13, 2004 | 10:16 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Default Re: Anyone ever do a 4 corner balance? (Clay)
I've been thinking about getting the car corner weighted and semi-race alligned. Might have to do this!
Old May 14, 2004 | 11:28 PM
Too Tall Z06's Avatar
Too Tall Z06
Does anybody know a place in socal that does this?
thanks
Old May 15, 2004 | 02:03 AM
'97 C5's Avatar
'97 C5
Default Re: Anyone ever do a 4 corner balance? (Too Tall Z06)
LAPD has digital scales and does the corner weight adjustments - talk with Al.
Old May 15, 2004 | 10:22 AM
mountainbiker2's Avatar
mountainbiker2
Guldstrand motorsports in Burbank. 818 558-1499
thanks
Old May 15, 2004 | 11:30 AM
Gramps's Avatar
Gramps
Put me in the right seat, problem solved!
Old May 15, 2004 | 01:02 PM
ZO6Les's Avatar
ZO6Les
My car is having that done (corner weighting) with a more aggressive alignment at this moment. I expect great things at VIR in June
Les
Old May 15, 2004 | 03:30 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
My car was corner weighted when it was prepared by Phoenix Performance last year.
This year, I bought my own scale system so I could verify the corner weights myself without having to drive from Memphis to Philly where Phoenix is located.
I now verify them before every race.
As mentioned above, it is very hard for me to separate the corner balancing from the other alignment settings.
I will say that while it might not be critical, it is important.
Here is an interesting article on the topic: http://www.grmotorsports.com/cornerweight.html
Old May 17, 2004 | 09:19 AM
gotto41's Avatar
gotto41
Default Re: Anyone ever do a 4 corner balance? (Subdriver)
I met Heinrocket at Pocono two years ago and while we were discussing how to prep a Z for the track, he stated that cornmer-balancing the car is one of the most important things you can do.
Old May 29, 2004 | 04:17 PM
dmiller's Avatar
dmiller
7th Gear
Default Re: Anyone ever do a 4 corner balance? (gotto41)
Does corner weight add weigts to the car or is it acheived through adjusting the suspension and alignment?
Would adding weight in the bottom of the trunk help prevent wet weather spinouts?
Old May 29, 2004 | 09:49 PM
rgregory's Avatar
rgregory
Default Re: Anyone ever do a 4 corner balance? (dmiller)
It is achieved through spring adjustments. The important thing is getting the cross weights the same (right front + left rear = left front + right rear).
Old May 29, 2004 | 10:57 PM
C66 Racing's Avatar
C66 Racing
Default Re: Anyone ever do a 4 corner balance? (rgregory)
Exactly. You can change the side to side or front to rear weight ratio's without actually moving weight around. Normally when corner balancing, you raise or lower one corner and you get a change on that corner on the diagonally opposite corner in the same direction.
When cross weight is 50.0% the LR + RF = 50.0% of the weight and the LF + RR = 50.0%.
Old May 29, 2004 | 11:39 PM
1%r's Avatar
1%r
St. Jude 15 Year Donor
St. Jude Donor '03 through '17
4 corner balance is a must!
Old Jun 3, 2004 | 08:40 AM
gotto41's Avatar
gotto41
Default Re: Anyone ever do a 4 corner balance? (jersey jay)
A note:
If you go with an aggressive alignment (camber), kiss your tires good bye. The inside edge will go in a few DE's.
Old Jun 3, 2004 | 10:45 AM
mikeo's Avatar
mikeo
A lot of the responses seem to indicate that corner balancing is great for racing. Is there any benefits (or potential harm) to corner balancing my Z that is just used on the street? Many thanks.
Old Jun 3, 2004 | 02:01 PM
woosch's Avatar
woosch
Default Re: Anyone ever do a 4 corner balance? (mikeo)
Just had mine corner weighted and aligned... All I can say is that there is a night and day difference
It will help your car even if you only drive on the street but it is almost a must if you plan to do any track driving
To Anyone ever do a 4 corner balance?
Old Jun 13, 2004 | 12:10 PM
C66 Racing's Avatar
C66 Racing
Probably not as important for street driving, but certainly will do no harm.
Old Jun 13, 2004 | 12:16 PM
stano's Avatar
stano
Great question Mike, just what I was thinking
And how much for this???
Old Jun 13, 2004 | 10:52 PM
ZO6Les's Avatar
ZO6Les
Default Re: Anyone ever do a 4 corner balance? (woosch)
The 4 corner balance was the best thing (other than the 383) that I have had done for the car. Much improved street manners, an amazing difference. Probably not a big deal for a street driven only car, unless you are an "aggressive" driver in the turns.
Les
