[Z06] Engine replaced in Z06
Old May 29, 2004 | 12:26 AM
clintw's Avatar
clintw
Default Engine replaced in Z06
I have a 2002 Z06 with 13000 miles and 2 weeks ago the engine died while I was driving on the HWY @ 70 - 80 mph.
I had it towed back to the dealer and they take it apart and discover the pin in the end of the cam has come out and the bolts connecting the cam to the timing chain sprocket have sheared off. Had several bent pushrods, bent valves, and 1 broken valve, the head on the #3 exhaust valve broke off and was stuck sideways in the piston.
I got the car back today with a new engine. Everything seems OK with the new engine, but I plan on taking it easy for the first 500 miles, so I haven't got on it yet to know if the power is any different then the old engine.
The part number for the replacement engine they used is 89017349
I have tried doing a web search on this part number, but haven't found anything. Does anyone know anything about this part number? It is a LS6, right? I know there has been a few minor improvement since 2002, is this part number an exact replacement, or does it have any improvements?
Thanks for any information.
Clint
Old May 29, 2004 | 12:31 AM
lager99's Avatar
lager99
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Default Re: Engine replaced in Z06 (clintw)
Glad your back in the game but what a pisser for a new car.
Old May 29, 2004 | 01:59 AM
02 batmobile's Avatar
02 batmobile
Clint, that sounds scary!! Now I'm concerned about my 2002 Z06 doing the same....anyone heard of this happening before?
Old May 29, 2004 | 08:21 AM
Corvette SSX's Avatar
Corvette SSX
St. Jude Donor '08
Default Re: Engine replaced in Z06 (02 batmobile)
Unfortunately, I have heard of this happeing on several LS1's. It can be prevented though as there is a sign that it's happening. Start the car and look at the harmonic balancer. If it is wobbly or you notice that the belt is not aligned welll on all pulley's, have it checked.
Old May 29, 2004 | 11:52 AM
Scott03Z06's Avatar
Scott03Z06
Here's what gmpartsdirect has to say about that part number. Not real descriptive.
GM PART # 89017349
CATEGORY: All
PACK QTY: 1 CORE CHARGE: $0.00
GM LIST: $8,686.50
OUR PRICE: $5,201.50
DESCRIPTION: ENGINE
Old May 29, 2004 | 05:09 PM
Wolf Dog's Avatar
Wolf Dog
I threw a valve on my '02 with 22,000 on it. I had been noticing what I thought sounded like a weak valve spring and sure enough it broke and...well you know what happened from there! The valve stem got pushed out the exaust and lodged in the opening to the right cat! The local dealer didn't bat an eye...they ordered a new motor from Michigan and had it in within two weeks. It does give rise to concern as I'm obviously not the only one that has had this type of problem with an '02. Glad your dealer was so helpful!
Steve
Old May 29, 2004 | 06:55 PM
Shylor's Avatar
Shylor
That just makes me cringe thinking about having a dealership service department changing out an entire engine. I keep thinking about all the bolts they would forget or torque incorrectly. Not to mention paint scratches. I've had such bad experiences with minor repairs from service departments that I can't image letting them do a major job like this on my car. I hope everyone that has stuff like this done actually looks at their car carefully, don't take the dealerships word that things are done right. I get up and in my car everytime before I leave a dealership....and sure enough without fail, I find stuff not finished. But with warranty repairs what are we to do.
Old May 29, 2004 | 10:37 PM
clintw's Avatar
clintw
Default Re: Engine replaced in Z06 (Shylor)
I certainly agree with your concerns about dealers doing repair work. The vette broke down less then 1000 yards from a large Chevy dealer and I had the car towed to a dealer that I trusted 40 miles away.
Also, I want to give a big thanks to a fellow Corvette enthusiast that stopped and offered assistance, I didn’t get his name, but he was driving a nice C3.
Old May 29, 2004 | 10:48 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
I bought a LS6 crate motor last July when mine had a seized rod bearing during a practice session.
My understanding is they come off the assembly line and turn some into crate motors. Mine had been built in Dec 02, os it was definitely an 03 motor. It came with a build date sheet on it.
You should be fine.
Old May 29, 2004 | 10:58 PM
clintw's Avatar
clintw
Default Re: Engine replaced in Z06 (Subdriver)
This one had a build date of Dec 2003. It was a complete engine missing all accessories (no intake).
Old Jun 7, 2004 | 11:23 PM
C66 Racing's Avatar
C66 Racing
That should be an 04 crate motor which is good.
Old Jun 8, 2004 | 01:45 AM
GOOSE JR.'s Avatar
GOOSE JR.
When I looked into a cam for my 2003 Z06 the shop told me that achange of the stock springs,rockers ,push rods and the cam retainer bolts was agood idea even before a cam swap. The reason being poor quality of the GM parts.
Old Jun 8, 2004 | 07:35 PM
MaverickC5's Avatar
MaverickC5
oh gtreat. glad it worked out for all of you!
Old Jun 8, 2004 | 09:48 PM
MrCrowley's Avatar
MrCrowley
Yes, very glad it worked out for you!
[Modified by MrCrowley, 8:49 PM 6/8/2004]
Old Jun 9, 2004 | 09:35 AM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
Default Re: Engine replaced in Z06 (GOOSE JR.)
Dayum.
So all of us with stock Vettes are driving around with junky,inferior parts in our engines?
Old Jun 9, 2004 | 10:23 AM
vettezosix's Avatar
vettezosix
Don't worry...it should have improvements on it! I have a 01 Z and had the entire engine replaced with a 03 engine due to oil comsumption problems and never had the problem again. It runs 10 times better than it did and it's nice to have a brand new engine and tranny with plate, clutch and all with the 03 parts @ 28,000 miles. So you shouldn't have any problems.
Old Jun 12, 2004 | 07:16 PM
MonarchZ06's Avatar
MonarchZ06
Yes, my brother has a 2001 Z06. His did almost the exact same thing. He (StockerZ06) is somewhere on here.
To Engine replaced in Z06
Old Jun 13, 2004 | 09:18 PM
JSF-F22's Avatar
JSF-F22
I had basically the same problem on my 2002 Z06 at around 15,000 mi. Some of the timing chain to cam bolts were sheared and the remaining bolts were loose. They found a sheared pin and metal shavings in the oil pan, the cylinder walls were scared, etc. The replaced the engine and I did not have any problems since; however the new engine never felt quite as strong as the orginal on did before it died.
Old Jun 13, 2004 | 10:55 PM
Gene@FredBeans's Avatar
Gene@FredBeans
The 89017349 is the 2004 LS6 engine part number.
Gene
Old Jun 16, 2004 | 12:04 AM
clintw's Avatar
clintw
Thanks for all the replies guys.
I just got pictures of the old engine.
